hi all. I have my Pi2 connected to my Sony amp which is then connected to my Samsung TV.
Since installing the latest version of rasplex I keep waking up to find my amp and TV have switched themselves on in the night.
Previously if I switched the amp on and selected the “Ras-Pi” source on the amp my Tv Would switch on and default to the right input. Or if using another source on the TV, Selecting the amp source would turn on the Amp and select the “Ras-Pi” source on the amp.
But now it looks as though the Pi is sending something to the amp on its own at random intervals.
I’m using the most up to date versions of both Rasplex and PMS and haven’t changed anything in my setup or plex settings so I’m not sure why this is happening.
So far the only solution is to unplug the Pi when I’m not using it.
