Raspberry Pi2 switches my TV off (over HDMI)
i've switched my Raspberry Pi against a Raspberyy Pi 2 with Rasplex 0.6.0. When i choose "Shutdown" on the Rasplex-Menu it also turns off my TV. I remember that i could confgure this on the old Version, so that my TV stays tuned after i switched off the old Raspberry.
I couldn't find this possibility at the new Version. Is it deleted or am i too blind to find it?
Thx a lot
Milly
This isn't really an answer, but it's a sort of question along similar lines.  I've only had my RPi2 with Rasplex 6.0 for a week.  One day last week, it 'picked up' my TV remote during boot up - I can't remember what it said on the screen and it hasn't done it since.  Anyway, on that particular day every time I switched my TV off with the TV's remote, it would switch off and then a few seconds later, the RPi (I'm guessing) brought the TV back to life again - it did this about 3 or 4 times before I eventually powered down the RPi.  Once I'd powered down the RPi I was able to switch off my TV as normal.
Thx a lot
Milly
You need to change the CEC settings in Preferences->System->Input Devices->Peripherals, select the CEC adapter and set the settings to what you want.
Regards
This is what i was looking for:
I will try it tonight.
Thx!
That's it.
Thx a lot again.
