Symbolic Links for Sync+
HI Guys
As always appreciate your support, plex is installed in a home directory with limited space.
So as I have done before I created symbolic link for Sync+
So I did this command
ln -s /var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Cache/Transcode/Sync+ /allstorage/media/plex/Sync+
with var/lib… being the plex installed directory and /allstorage…being my attached storage
however I am still the server’s disk is almost full error when trying to sync.
In the directory /allstorage/media/plex/Sync+
I can see the symbolic link listed as shortcuts the following
Application
Media
Plex
Sync+
can anyone let me know what I have done wrong please?
many thanks in advance
Bill
I made one change which seemed to help
i changed the command to the following
ln -s /var/lib/plexmediaserver/Library/Application\ Support/Plex\ Media\ Server/Cache/Transcode/Sync+ allstorage/media/plex/Sync+
this has now created a link correctly in the folder I only see Sync+ in the directory
but i still see the error
Please remember.
ln -s  /path/to/where/it/is    /path/to/where/you/want/the/name/placed
Looks like your symlink is backwards.
You want it to be out on the bigger space but to place the Sync+ name in /var/lib/plexmediaserver
