Sync failed with TrueHD 5.1 and 7.1. Stream work very well
Hi.
Since a few weeks, I started to sync on my ipad video. 75% of video that contains TrueHD 5.1 and 7.1 audio failed. In stream, work very well.
I will do several tests and add the logs each time. Thanks for reply.
Rampage (2018)
Same issue workaround (of sorts) is to remove TRUEHD track and it will sync.
Me too. Everytime.
Hi. 3 others movie whit TrueHD crash on Optimized or Sync.
A Quiet Place (2018)
A Quiet Place (2018).txt (7.7 KB)
Escape Plan 2 Hades (2018)
Escape Plan 2 Hades (2018).txt (7.3 KB)
Rampage (2018)
Rampage (2018).txt (6.8 KB)
Logs
Thx for your help.
Braveheart (1995)
Braveheart (1995).txt (7.6 KB)
First Knight (1995)
First Knight (1995).txt (6.8 KB)
Ghost in the Shell (2017)
Ghost in the Shell (2017).txt (7.3 KB)
Logs
Thx
Not sure if Sync is the same problem but failure to optimize videos with TrueHD is probably related to this: Conversion failed. The transcoder exited due to an error (Memory Allocation failures)
None of your logs show any error on sync. What is reporting the error? and exactly what times?
You have verbose logging enabled so logs only cover a short timespan
We have periods
4th August 21:32:23. up to 21:50:15
7th August 19:04:04 up to 20:13:25
16th August 23:48:03 up to 17th August 03:52 am
Where was the error displayed and exactly what time
It may be necessary to also have the plex app logs as well to go with the server logs
Please disable verbose logging and just keep debug logging enabled on the server to get longer time cover in the log
Hi. Thx for your reply. I will start all over again and say the errors minute by minute and a log for each movie.
Start Optimize First Knight (1995).mkv at 17:28
Crash 28% and at 17:41
Plex Media Server Logs_2018-08-17_17-42-30.zip (3.3 MB)
Do you need more?
That is good
Need to understand what you have in place in terms of paths for optimization
So this video was being optimized
Aug 17, 2018 17:40:30.611 [12072] DEBUG - [Universal] Using local file path instead of URL: \\HARDDRIVE12\Public\Version 07\1 - Movies American\1 - Full EN-FR\First Knight (1995)\First Knight (1995).mkv
and the transcoder logged an error for the path used for optimization
Aug 17, 2018 17:40:30.858 [9768] ERROR - [Transcoder] C:\Test\Plex Versions\Custom_ Universal TV 2567\.inProgress\First Knight (1995).mp4.2567: No such file or directory
I am not sure if it is to do with permissions or space or an invalid path
It’s really weird. Streaming, everything is fine. All movies with TrueHD, error by optimizing. I’m going to move it in the c: I’m going to optimize it and I’m going to optimize one in the same hard drive HARDDRIVE12 sans TrueHD.
In what log I can see his error?
The error was in the Plex Media Server.log
This log file gets moved to Plex Media Server.1.log when it reaches 5Mb in size or when you relaunch Plex Media Server. All the logs shift up by 1 - so oldest would be Plex Media Server.5.log
Any diskspace issue on c: ?
over 400gb
crash again
19:51 to 20:06
Plex Media Server Logs_2018-08-17_20-06-21.zip (3.4 MB)
Now i optimize another movie from HARDDRIVE12 to c: but no Truehd.
Friday Night Lights (2004)
20:06 to 20:34 no problem
Plex Media Server Logs_2018-08-17_20-33-58.zip (3.4 MB)
Good morning.
I did another test which, I think, proves that there is a problem with the TrueHd.
Ghost in the Shell (2017).mkv whit TrueHd track.
Start at 4:03 and crash at 4:18
Plex Media Server Logs_2018-08-18_04-20-35.zip (4.2 MB)
After that. I used MkvToolnix to remove the TrueHd track. Remove the source and scan to keep the movie without the TrueHd track.
Start at 4:29 done without problem at 4:42
Plex Media Server Logs_2018-08-18_04-43-37.zip (4.1 MB)
What I noticed.
Whit TrueHD track:
CPU usage: not over 10%
RAM: up to 3400mb
Ghost in the Shell (2017)1.txt (7.2 KB)
Whitout TrueHD track:
CPU usage: 50-70%
RAM: 280-390mb
Ghost in the Shell (2017)2.txt (6.2 KB)
My Pc:
I-9 7900x CPU
32gb RAM
THX
