So this is more a client side issue but basically, if you downloaded some media then deleted the server, you cant delete the media from the client device. In order to delete that media, you have to delete the app.
Server Version#: TerraMaster (Latest)
Player Version#: IOS
Are you using “Sync” or “Downloads”?
Sync is on its way out, so if it is happening with Sync’ed content, this issue will very likely not getting fixed.
