Server Version#:3
Player Version#:5.76.2
Running on Drobo
Just recently I am getting prompted after every movie or episode to turn on Sync. No matter if I click no or yes, it comes up every time. Is there a way to make it go away?
Thanks,
Server Version#:3
Running on Drobo
Thanks,
Not sure what player this is. Do you mean you see it in the browser? If from browser, which are you using. Also is the browser being closed an open each time
The player is on a Samsung TV. I haven’t tested on a browser yet but will do that now.
Thanks.
Is it possible to get the smart TV logs after it happens.
there are instructions in link above in my previous post. basically you enable logging to server in the app then it will write to your server logs and you grab those
Also want to confirm if this is happening even if you don’t close the app and reopen between playbacks. I have a feeling it does not matter but wanted to check. It is an account level option so it sounds like the app cannot communicate with plex.tv to save to your account
It happens when a show completes and if I back out of the show. It does not do it in the browser.
This is still an issue.
Can you share your smart tv logs after it happens @jogv3
Im having exact same problem, i check the logs and here are the errors
Plex Media Server Logs_2024-05-04_10-43-47.zip (2.9 MB)
No, I’ve moved on to Emby.
Just started having this problem as well on 9/21,
Same for me using a Samsung TV
Also have a Samsung TV this has been an ongoing issue for several months now. Our other TV’s don’t prompt for this only the Samsung.
