Synology 218+ with DSM 7 - NAS not detected
Server Version#:
DSM 7.0-41890
I have installed on my Synology 218+ with DSM 7 Plex…but i have an issue: my NAS is not detected. I read a lot of discussions about this but i have not solved my issue. Someone can help me please?
Thanks.
I have the same issue with my 216play.
Server wont show up even when i connect via the local IP. I even tried deleting everything incl. logs but even after the reinstall nothing works :frowning:
Have you found a solution?
Have you tried with @trumpy81 guide?
Can you manually navigate in FileStation, into PlexMediaServer, until you see “Logs” .
Right click Logs and “Compress to Logs.ZIP” then attach here please
I think I know what’s happening.
Thanks for the reply :slight_smile:
Tried what @trumpy81 suggested already.
Find the logs folder attached.Logs.zip (153.9 KB)
Also for some reason i seem to have two plex folders on the DS one called “Plex” and the other “Plex Media Server” could that affect things too?
Cheers,
Killermops
The Plex shared folder is left over from DSM 6.
On DSM 7, we don’t have sufficient privilege to remove it.
Also, it would be rude to delete it as many people have media stored there (which is OK to do now in DSM 7)
On DSM 7, effective 1.24.2.4973, PlexMediaServer is available per these release notes:
