NAS not seen by Plex DSM 7 synology update
Server Version#: Synology DS218+ NAS
Hello
I have a snyology DS218+ Nas and I have just installed the DSM 7 update. I now cannot access my NAS via the plex app . It keeps saying that my nas is unavailable.
My smart TV and my nvidia shield cannot access the server either.
I cannot watch any of my content as a result.
thanks
Jim
Did you see the documentation and migration instructions?
I have the same problem with DS218 + and current version DSM 7.0.1, I tried to install the AMRv7 version from your site but it doesn’t let me install it. Can you send me the correct spk file? Thank you
@alecalderone_libero_it
Which Synology model do you have ? (there are several variants of ARMv7)
I downloaded and tried to install this: ARMv7 (x15 Series (excluding DS115j and RS815), x16 Series (excluding DS216se), x17 Series, x18 Series, and DS414j)
The DS218+ has an Intel J3355 CPU.
Choose Synology (DSM 7) and download the Intel 64-bit version.
https://www.plex.tv/media-server-downloads/#plex-media-server
My apologies for missing this :man_facepalming:
Ciao,
ho effettuato download della PLEX indicato, adesso quando provo a istallarlo ricevo il seguente messaggio. Ho abilitato Plex alla scrittura e lettura e ricevo sempre lo stesso errore.
Tranquillo, se anche tu hai soluzioni puoi farmi sapere? Grazie
Ho risolto, ho inserito altre abilitazioni, grazie a tutti per i consigli utili.
Non “utente” Plex
Vuoi “Utente interno di sistema” PlexMediaServer
Nell’angolo in alto a sinistra, cambia “Utente locale” in “Utente interno di sistema”.
Ora vedrai “PlexMediaServer”.
Not “user” Plex
You want “System Internal User” PlexMediaServer
In the upper left corner, change Local User to System Internal User.
Now you will see PlexMediaServer
