version: "2.1"
services:
plex:
image: lscr.io/linuxserver/plex:latest
container_name: plex
network_mode: host
environment:
- PUID=1036
- PGID=100
- VERSION=docker
- PLEX_CLAIM=claim-###
devices:
- /dev/dri:/dev/dri
volumes:
- /volume5/docker/plex/config:/config
- /volume5/data/media/tv:/TV
- /volume5/data/media/movies:/movies
- /volume5/data/media/kids/movies:/kidsmovies
- /volume5/data/media/kids/cartoons:/cartoon
restart: unless-stopped
I can’t manage to have the transcoding setting on my 918+
I added since a docker volume /volume5/docker/plex/transcode:/transcode
and I edited the docker file to added
"CapAdd" : null,
"CapDrop" : null,
"cmd" : "",
"cpu_priority" : 0,
"devices" : [
"CgroupPermissions" : "rwm",
"PathInContainer" : "/dev/dri",
"PathOnHost" : "/dev/dri"
I also created a script a boot
#!/bin/bash
#Startup Script
#Access for HW Decoder Plex
chmod 666 /dev/dri/renderD128
exit
But yet I don’t have any transcoding hardware option on Plex and while it was working fine with the Plex Package, I have a lot of lag new.
– playing the same file with infuse work juste fine (assuming it doesn’t need transcoding with infuse)
anyway to enable hardware acceleration or bypass the transcoding ?
PS when I do a speedtest with infuse (SMB) I’m around 450Mbps
(The DS918+ use two M2.SSD as drive but the speed is limited by the hardware, the DS918+ is connected to a 10Gb switch, Layer 3 --but limited with the 1Gb NIC , client AppleTV 4K / MacMini
from SSH (not plex user)
:/dev/dri$ ls -la /dev/dri
total 0
drwxrwxrwx 2 root root 80 Nov 27 14:56 .
drwxr-xr-x 16 root root 14600 Nov 27 23:05 ..
crwxrwxrwx 1 root root 226, 0 Nov 27 14:56 card0
crwxrwxrwx 1 root videodriver 226, 128 Nov 27 14:56 renderD128
