Server Version#: 1.19.1.2701
I run plex server on my Synology ds918+. Bought Plex Pass in order to use hw-transcoding and thought I should be able to play most kind of videos. When I try to play a video on my Apple TV 4k using the Plex App (experimental player) it takes like 1 minute before it starts playing and after that, I can watch a couple of seconds before I get some popup saying that the server could not handle this video. If I use Infuse on my Apple TV, the video plays without any problem. All my devices are connected trough wired gigabit ethernet. Is this expected? I thought my synology in combination with plex pass were supposed to be able to handle this or was I wrong?
The media file I am trying to play is:
- Codec HEVC
- Bitrate 42076 kbps
- Bit Depth 10
- Chroma Subsampling 4:2:0
- Coded Height 2080
- Coded Width 3840
- Color Primaries bt2020
- Color Range tv
- Color Space bt2020nc
- Color Trc smpte2084
- Frame Rate 23.976 fps
- Height 2076
- Level 5.1
- Profile main 10
- Ref Frames 1
- Width 3840
- Display Title 4K (HEVC Main 10 HDR)
