Or you should use the Synology Channel to release the update…
@firefox87 I asked a few month’s ago if that were a possibility, but I recall ChuckPa told me that with the way Synology works, it takes ages for each submission to be released. Which means you will always be a few (or many) versions of PMS behind…
Hi know that… I hope that the issue was made accidentally from Synology, because they release the RC and the last release Plex doesn’t work is so strange…
TO ALL FOLLOWING HERE:
I have replaced the package builds here with an updated set for PMS 1.23.3.4706
PLEASE “Like” this post if it works for you. Please help keep the thread short.
works for me! good work, merci
Thanks, Chuck, the updated file worked for me too!
Updated file worked for me as well! Thank you @ChuckPa !!!
can you pls make an spk for armv7hf_neon? Thank You
The package name changed as of 1.23.0
armv7neon is its new name.
(It’s also why there was breakage on the downloads page)
The downloads page will be listed correctly but this is the new File name.
I’m getting an ‘invalid file format’ message when trying to install this.
Any ideas? I’m on a DS414
You are using DSM 7.0.41882 ?
Which of the above files did you install ?
All I did here was to repackage the production binaries with the new INFO file Synology requires.
I got the file installed, Chuck, but while the metadata is all there, files are showing as unavailable. What am I doing wrong? (Thanks in advance!)
If you did an Uninstall - Reinstall – then you need to add “System Internal User” PlexMediaServer 's permissions back to each shared folder again.
DSM 7 is really strict on this.
(I had to do the same thing in my testing)
Thanks for such a quick reply, Chuck. I’ll try that. Really appreciate your work!
Sorted, Chuck! That’s working now.
You are an absolute legend!
3 posts were merged into an existing topic: Plex Media Server - Synology DSM 7 Preview - Issues
FOLKS
There is further breakage
New DSM 7 installations fail. There is no means by which to “migrate” a DSM 6 installation
There is nothing we can do until Synology updates DSM 7 again
I have alerted Synology as this is an “All Stop” event.
It works fine for me on DS918+ DSM 7.0-41882. Thanks!
Hi, any chance the same can be done for this new PlexMediaServer-1.23.2.4625-a83d2d0f9-x86_64_DSM7 package that is proposed by Plex today? Because I also get the ‘Invalid file format. Please contact the package developer’ warning.
TIA
