OK, wife wanted to record Olympics so after some research I decided to try a HDHomeRun CONNECT Duo - it seemed to be a good solution. Don’t watch much TV at our house.
Plex is on my Synology DS412+ which supports transcoding.
I have Plex Pass (obviously) but I did not purchase HDHomeRun DVR software yet.
Set up DVR in Plex and it looks good. Then when it comes to a show to record, it shows a “transcoding error”. When I start another recording - it looks like it’s working - only to stop in a few minutes. Even after a couple of trial recordings over night (who knew Night Court was still on?) and trying to figure it out, looks like nothing is saved on my server.
I read through quite a few “transcoding error” posts but nothing seems to be the same / works for me.
Do I need to purchases HDHomeRun’s software in addition to plex pass? Is there another setting I’m missing?
I had a similar issue with a new HDHomeRun Prime and Plex whereby many scheduled recordings would be only about ~6min in length. I believe some recordings completed though.
In this case, the issue wasn’t exactly with the HDhomeRun or Prlex but rather the combination under the given firmware.
Keep in mind it was a new HDHomeRun Prime but the firmware was old. Once I updated the the HDHomeRun Prime’s Firmware this issue of incomplete recordings simply went away.
If you haven’t already I would strongly suggest you check your firmware and updated it.
