I recently updated to DSM7 and therefore also updated Plex Media Server. Everything is working fine except that it seems I need to redo or refresh the permissions for the “Media” folder for user “PlexMediaServer” every day. At the moment if I add a new movie to the media folder, Plex will not recognise it (even if I force “scan library”). But if I log into Synology and redo the folder permissions (even though they are already correctly set) it then allows Plex to see the new content when I “scan library”. That will continue working for a few hours until I must redo the permissions again. Very frustrating. Any ideas on how to make the permissions settings “stick”?
Thanks ChuckPa, I think I understand now. I use a combination of Sonarr/Radarr or sometimes just NZBGet by itself. So, Radarr (for instance) is adding a file that only it has ownership of, and therefore Plex can’t see it.
I came across another post by yourself where you said: 3. On Synology, best permissions are either: a. Assign no permissions in Radarr/Sonarr and let Control Panel - Shared Folders - Permissions tab handle it b. Assign 755 for directories and 644 for files.
So are you saying to configure Radarr (for instance) to save files with 755/644 permissions? I’m using Radarr via Docker - is it the container settings I need to change to fix the permissions?
the PUID/GID which wrote the files (presumably your Synology username) maintains ownership
PlexMediaServer gets the permissions of the last digit (the “Other” value) which is Read/Execute for the directory so it can traverse it to get to the file and “4” so it can read the file.
Remember, on Synology, the default action is to inherit the permissions of the parent directory so I tend to leave these alone.
If you must set them -
In Sonarr, setting the value “755” will be edited by Sonarr to “644” (we don’t execute media files — unless they’re naughty )
This screenshot is from my currently running Sonarr configuration.
Sorry, I misread your earlier post but realised a bit later on.
I only vaguely understand how the UID/GID works so I’m not sure if they are not matching. I think I will try ticking the box and see how that goes! Thanks for your help
Thanks ChuckPa, I followed your steps. After testing, I found that Sonarr worked but Radarr didn’t. I then realised it may be because I had configured nzbget to run the VideoSort script for the “Movies” category only (not “TV”). So I updated the PGID in the nzbget container as well, and now everything seems to work. Thank you very much!
