DS710+
DS1010+
RS810+
DS411+
DS411+ II
DS1511+
RS2211+
For other models, check below the "what about ARM/PPC builds" chapter.
Since [the official Synology package is now released](http://www.plexapp.com/linux/linux-pms-download.php), I decided to do a new thread in order to better keep track of things related to it.
**What does the package do?**
It:
- installs the Plex Media Server (duh),
- creates a "plex" user, which will run the PMS,
- creates a "Plex" folder in your main volume, containing the library,
- configures everything automatically: Avahi, rsync, etc.
- creates a "Plex Media Server" icon in the DSM, to access the Media Manager:
http://dl.dropbox.com/u/27482871/DSM.png
**I installed the previous version of the package. How do I upgrade?**
The best way to do that is to upgrade the package in the DSM, as if you tried to install it.
I strongly recommand **NOT to uninstall/re-install.** The main reason behind this is that the Library is huge.
**I still want to do a full clean install!**
Okay, in this case, here are the steps:
1) uninstall the package.
2) remove the Plex shared folder. This is very, VERY long (as in "hours"). Better do it via SSH.
3) re-install everything.
If you want to keep the Library, you'll have to do a "chown -R plex:users /volume1/Plex" after re-install (the user was deleted/created, so the rights are not set correctly).
**What about ARM/PPC builds?**
This is a more general issue; I recommend that users who want ARM/PPC build post in this thread, created by thorsten: http://forums.plexapp.com/index.php/topic/29208-on-which-synology-diskstation-would-you-like-to-run-pms/
I'm just the guy that does the package, not the binary inside it. :P
**Bugs are still okay here?**
Well, to be honest, since the binary is the same source code between environments (ReadyNAS especially), you'd be better to create threads/post in already-existing threads for those issues.
Again, this is to get the devs' attention.
**So, what goes here?**
Install, uninstall, upgrade, crashes or "it's not running at all" issues.
Also, issues like the Resource Manager not running (by the way, Elan contacted Synology about that, and they're preparing a DSM release with a fix for that. My gut instinct was right. :D ).
