Server Version#: DSM 6.2.2-24922 Update 4 - DS1019+
Player Version#: 1.18.5.2309-f5213a238
Plex Media Server Logs_2020-04-15_23-59-55.zip (184.3 KB)
Plex freezes. I have to reboot. Not sure what else to include.
Bryan
Bryan
Plex Media Server Logs_2020-04-16_00-17-12.zip (148.7 KB)
I attached a verbose log. Just in case. I cleared logs, restarted. Then used my IPad, which always causes it to crash. Then waited and restarted it. This is the logs for that.
It freezes multiple times a day. I have to stop it and restart it. This started after some x updates ago. Its been running great on synology for a while.
I have been using plex for, I don’t know, 10 years. I use to have a Intel NUC running windows. Just started 6 month ago, running it on a new DS1019+ I bought. Wanting to simplify my system.
I will read this article for sure. I don’t have that complex of an install. I just installed it, and pointed to the media. That is it.
I have 3030 folders. I am trying this.
I will report back if that fixes the issues.
Regarding logs, got it. Sorry about that.
How do I “You need to clear out your Sync lists and delete any failed/incomplete Sync jobs.”
Here are the logs requested. After install. I have set it to debug. Just not sure if the previous verbose are still in there. Just did not want to delete whatever was there.
Plex Media Server Logs_2020-04-16_13-59-11.zip (3.5 MB)
Thanks for your help BTW!
I did optimize the database last night sometime during this process. Did it again for good measure.
I had one sync going on with an IPAD. Removed it. Will remove from the device as well.
I have tried to break it since all the changes, which was pretty easy to do before, and have not been able too so.
If it freezes again. I will post logs.
Again, thanks for your help!
Just to report back. I have not had an issue since.
Thanks for all your help.
