Taskmaster (SE) matching problems
I have added a bunch of episodes of Taskmaster (SE), but they keep getting matched as Taskmaster.
Tried renaming the files like this:
/TV Shows/Taskmaster (SE)/S3/Taskmaster (SE) - S03E02 - Keyyo visits.mkv
As I already have Taskmaster Season 3, I can’t fix match on the show…
Include the year, and to be extra sure, you can also include the tvdb/tmdb id to the folder as well if you’re using the Plex TV Series agent:
/TV Shows/Taskmaster (SE) (2017) {tvdb-325248}/Season 3/Taskmaster (SE) (2017) - S03E02 - Keyyo visits.mkv
Since they’re in different root folders, you can still manually split them apart (at the show level, not season/episode), and then fix the match of the split show.
Relevant parts of the naming guidelines:
  • For the “Plex TV Series” agent, it is recommended to always include the year alongside the series title in folder and file names, e.g. /Band of Brothers (2001)/Season 01/Band of Brothers (2001) - s01e01 - Currahee.mkv
  • If you are using the “Plex TV Series” agent, you can optionally include the TMDB or TVDB show ID in the folder name to improve matching. If you choose to do that, it must be inside curly braces: ShowName (2020) {tvdb-123456} or ShowName (2020) {tmdb-123456} where 123456 is the show ID. An example can be found at the end of the article.
Thank you so much!
Split apart and then fixing match did the trick =)
