Tautulli - Monitor your Plex Media Server
@SteveG144 said:
@JonnyWong16 I’ve been getting a error when using the Twitter notification. I can attach the log if it helps, but it says:
Tautulli Notifiers :: Twitter notification failed: media type unrecognized.
What version because I fixed that in v2.1.2-beta 13 days ago. Current version is v2.1.4.
I will have to check when I get home. Don’t have remote access to that system.
@JonnyWong16 I am using the v2.1.4 version when I get the Tautulli Notifiers :: Twitter notification failed: media type unrecognized
You’re not giving me enough info to go on. One error from the logs doesn’t tell me anything.
Post your complete logs. What is the commit hash? What are you Image hosting options? What are your Twitter options? What is the {poster_url} (add that to your actual notification text so you can troubleshoot it)? I shouldn’t have to ask for this info.
@SwiftPanda16 said:
@SteveG144 said:
@SwiftPanda16 I am using the v2.1.4 version when I get the Tautulli Notifiers :: Twitter notification failed: media type unrecognized
I downloaded the zip from GitHub - Tautulli/Tautulli: A Python based monitoring and tracking tool for Plex Media Server. this morning and set up settings again.
Hosting images on Cloudinary
Poster_url (which you said wasn’t needed if the option to include the poster image) - http://res.cloudinary.com/dndipf06u/image/upload/v1526393106/poster_8794.png
Log is attached
Twitter images:
Log is attached
Twitter images:
Not the proper way to post logs: GitHub - Tautulli/Tautulli-Wiki: Wiki for Tautulli
But thanks. Now I know exactly what to fix.
Plexpy / Tautulli Libraries problems
Windows 10
Tautulli Version v2.1.4
After I had to rebuild my computer, I wanted to bring in my about 2 weeks old Tautulle Data Base File backup!
Action :
Tautulli finished
The old Data Base file deleted
My backup inserted
All stats are back so far so good!
Problem: All libraries are duplicate
How can I fix this?
Sorry for the bad English is google translated :wink: (German answers I accept gladly)
Windows 10
Action :
Tautulli finished
My backup inserted
How can I fix this?
Perfekt :wink: THX
Is there a way to limit the # of resumed notifications? For some reason, too often Tautulli is sending me like 10 notifications within 15 seconds that a user is resuming a video. There’s no way they are resuming it 10 times, so why am I getting 10 notifications? Anyone else having this issue with the resumed notification?
I must say that I am super happy with Tautulli, I like that it has a good balance between raw stats and the gui, keep up the good work!
Hi Guys, I have somehow ended up using the BETA line of updates, is there a way I can get to stable and stay on stable?
also i’ve modified the plexpy.conf file to set git_branch=stable … but when i restart tautulli … it reverts the file somehow. ( /share/CACHEDEV1_DATA/.qpkg/PlexPy/CONFIG/plexpy.conf)
Git Branch: beta
Configuration File: /share/CACHEDEV1_DATA/.qpkg/PlexPy/CONFIG/plexpy.conf
Database File: /share/CACHEDEV1_DATA/.qpkg/PlexPy/DATADIR/tautulli.db
Log File: /share/CACHEDEV1_DATA/.qpkg/PlexPy/DATADIR/logs/tautulli.log
Backup Directory: /share/CACHEDEV1_DATA/.qpkg/PlexPy/DATADIR/backups
Cache Directory: /share/CACHEDEV1_DATA/.qpkg/PlexPy/DATADIR/cache
Newsletter Directory: /share/CACHEDEV1_DATA/.qpkg/PlexPy/DATADIR/newsletters
GeoLite2 Database: Click here to install the GeoLite2 database.
Arguments: [’–daemon’, ‘–port=8659’, ‘–datadir=/share/CACHEDEV1_DATA/.qpkg/PlexPy/DATADIR’, ‘–config=/share/CACHEDEV1_DATA/.qpkg/PlexPy/CONFIG/plexpy.conf’, ‘–nolaunch’]
Platform: Linux 4.2.8 (#1 SMP Fri Apr 13 01:15:22 CST 2018)
Python Version: 2.7.12 (default, Aug 21 2016, 01:11:52) [GCC 5.2.0]
Brad
@tycho1974 said:
@Migs said:
@tycho1974 said:
This is why I’m left scratching my head as to why one works but not the other. I literally copied and pasted my SMTP and login info from my PlexEmail config into the Tautulli interface, so I’m hesitant to assume that one of my settings is “wrong”. I can confirm that my PlexEmail scripts works properly, as it went out on schedule last night. My username is standard, and my password has the requisite special characters, as deemed necessary by my email server (the usual alphanumeric characters, and a single “special” character).
tycho1974, just a thought… do you happen to have 2-step verification enabled for your Google account ? If so, that would mean you would need an “app specific” password to be used for Tautulli with your Gmail account.
support.google.com/accounts/answer/185833?hl=en
I kinda ran into this problem when I was setting up my newsletters in Tautulli the other day using my Apple Mail account. I had forgotten I had enabled 2-step verification on my iCloud account and was getting verification errors. I finally remembered needing an app specific password, like Google does as well.
This may not be the issue in your case, just figured I’d throw it out there as a suggestion for you. Hope you get it figured out…
Thanks, but as I mentioned originally, I’m not using a google account; regardless, I’m not using any kind of TFA.
@JonnyWong16 — Any thoughts on this newsletter issue I’m having? I’ve tried using a gmail account, two separate private account that use an Office365 server, and nothing is working. I keep getting the same error:
ERROR Tautulli Notifiers :: Email notification failed: SMTP AUTH extension not supported by server.
I don’t know why this seems to work fine for other users but not for me. I’ve checked and re-checked the usernames, passwords, and SMTP server info and verified that they’re all current and correct.
Git Branch: beta
Arguments: [‘–daemon’, ‘–port=8659’, ‘–datadir=/share/CACHEDEV1_DATA/.qpkg/PlexPy/DATADIR’, ‘–config=/share/CACHEDEV1_DATA/.qpkg/PlexPy/CONFIG/plexpy.conf’, ‘–nolaunch’]
Brad
Same for me
@Davidson-NAS @DuffHQ
It’s likely NOT called “stable”, and, you can’t edit the config while Tautulli is running. It’s stored in memory, gets overwritten when tautulli shuts down.
That being said, I’d recommend using the settings in Tautulli
Settings - General - Show advanced, scroll to bottom - change from beta to master, check out.
@JamminR said:
@Davidson-NAS @SVKTV
  • Suddenly on beta branch without changing from master
  • Settings - General - Show advanced - Scroll to bottom
  • Setting is not there. Tried both firefox and chrome.
Since I updated to Tautulli the “Plex Update available” notification is no longer working from my Telegram notification Agent.
All other triggers work fine except for this one. Is anyone else having this problem?
@SVKTV said:
You’re running old no longer supported by JonnyWong16 Plexpy 1.x.
Upgrade to the new latest greatest and in many of our opinions, better, Tautulli (aka plexpy 2.0)
Keep your plexpy.db file for history, but you’ll likely have to recreate all your options (it’s worth it, much more powerful conditions for agents - see the wiki for how/config/etc)
@SwiftPanda16 - Bug?
Test email newsletter, inline CSS (still hoping you find a way to include that, but without the HTML indent whitespace in later in body.), beta 2.1.7
Email (and presumably cloudinary) is missing valid links to your icons and ‘View on plex’ overlays.
If these settings don’t show up, then you have a messed up git install.
@JamminR said:
@JonnyWong16 - Bug?
I already strip whitespace in v2.1.7-beta:
  • Change: Strip whitespace from newsletter for smaller file size before sending to email.
https://www.reddit.com/r/Tautulli/comments/8jzbr9/newsletters_in_gmail_broken_tautulli_images/
