2019-06-07 10:43:26 WARNING Unable to retrieve data for get_activity.
2019-06-07 10:43:26 WARNING Tautulli Pmsconnect :: Unable to parse XML for get_current_activity: 'NoneType' object has no attribute 'getElementsByTagName'.
2019-06-07 10:43:26 WARNING Failed to access uri endpoint /status/sessions. Is your server maybe accepting SSL connections only? HTTPConnectionPool(host='127.0.0.1', port=32400): Max retries exceeded with url: /status/sessions (Caused by ReadTimeoutError("HTTPConnectionPool(host='127.0.0.1', port=32400): Read timed out. (read timeout=15)",))
There are dozen of entries after the WARNING letting me know thing have been recently added & users playing media, so itās still working in the background and stuff.
2019-06-07 10:43:36 DEBUG Tautulli ActivityHandler :: Session 640 started by user xxxxx (xxxxx) with ratingKey 157223 (Trolls).
So, itās all working processing in the background and logging all activities. Itās just the frontend(home page, ACTIVITY section) that times out. Again, this only happen when/while I encode video. Can I increase the timeout session or something?
Tautulli Pmsconnect :: Unable to parse XML for get_current_activity: āNoneTypeā object has no attribute āgetElementsByTagNameā.
2019-06-10 23:30:16
WARNING
Failed to access uri endpoint /status/sessions. Is your server maybe accepting SSL connections only? HTTPConnectionPool(host=ā127.0.0.1ā, port=32400): Max retries exceeded with url: /status/sessions (Caused by NewConnectionError(ā<urllib3.connection.HTTPConnection object at 0x7fd7ec533910>: Failed to establish a new connection: [Errno 111] Connection refusedā,))
I donāt know when it started but for some reason my Tautulli app for Android doesnāt notify me anymore when someone starts a new stream. I get an email sent from Tautulli but nothing with the Android apps, even after a re-install. Is there something Iām just missing? It used to give me notifications.
When I check the logs I see: Tautulli Notifiers :: Tautulli Remote Android App notification sent.
So Iām running Tautulli v2.1.29, and I noticed a pop-up indicating that v2.1.32 was available.
Iāve āupdatedā three times now, but every time I remain at v2.1.29. I have Tautulli set to automatically update, and Iām using the origin master branch.
This is the relevant portion of the log after I click āupdateā every time:
2019-07-09 11:04:20 INFO Tautulli Config :: Writing configuration to file
2019-07-09 11:04:09 INFO Tautulli Config :: Writing configuration to file
2019-07-09 11:04:08 INFO Launching system tray icon.
2019-07-09 11:04:07 INFO Tautulli WebStart :: Starting Tautulli web server on http://0.0.0.0:####/
2019-07-09 11:04:07 INFO Tautulli WebStart :: Web server authentication is enabled: Tautulli admin (username is '####').
2019-07-09 11:04:07 INFO Tautulli NewsletterHandler :: Scheduled newsletter: Recently Added (newsletter_id 1)
2019-07-09 11:04:07 INFO Scheduled background task: Check for server response
2019-07-09 11:04:07 INFO Scheduled background task: Refresh libraries list
2019-07-09 11:04:07 INFO Scheduled background task: Refresh users list
2019-07-09 11:04:07 INFO Scheduled background task: Check for Plex updates
2019-07-09 11:04:07 INFO Scheduled background task: Check for Plex remote access
2019-07-09 11:04:07 INFO Scheduled background task: Refresh Plex server URLs
2019-07-09 11:04:07 INFO Scheduled background task: Backup Tautulli config
2019-07-09 11:04:07 INFO Scheduled background task: Backup Tautulli database
2019-07-09 11:04:07 INFO Scheduled background task: Check GitHub for updates
2019-07-09 11:04:07 INFO Tautulli WebSocket :: Ready
2019-07-09 11:04:07 INFO Tautulli WebSocket :: Opening websocket.
2019-07-09 11:04:07 DEBUG Tautulli Monitor :: Checking for active streams.
2019-07-09 11:04:07 INFO Tautulli NotificationHandler :: Starting background notification handler (2 threads).
2019-07-09 11:04:07 INFO Tautulli Libraries :: Libraries list refreshed.
2019-07-09 11:04:07 INFO Tautulli Config :: Writing configuration to file
2019-07-09 11:04:06 INFO Tautulli Libraries :: Requesting libraries list refresh...
2019-07-09 11:04:06 INFO Tautulli Users :: Users list refreshed.
2019-07-09 11:04:04 INFO Tautulli Users :: Requesting users list refresh...
2019-07-09 11:04:04 INFO Tautulli Config :: Writing configuration to file
2019-07-09 11:04:03 INFO Tautulli PlexTV :: Using user-defined URL.
2019-07-09 11:04:03 INFO Tautulli Config :: Writing configuration to file
2019-07-09 11:04:02 INFO Tautulli PlexTV :: Requesting resources for server...
2019-07-09 11:04:02 DEBUG Requesting URL via GET method: https://api.github.com/repos/Tautulli/Tautulli/releases
2019-07-09 11:04:02 INFO New version is available. You are 35 commits behind
2019-07-09 11:04:02 DEBUG In total, 35 commits behind
2019-07-09 11:04:02 DEBUG Requesting URL via GET method: https://api.github.com/repos/Tautulli/Tautulli/compare/6d35bd7947bad9e50772ab49bcc6c9c34979eeaa...2635569e765e5817400ed1032a27bfc850242f6a
2019-07-09 11:04:02 INFO Comparing currently installed version with latest GitHub version
2019-07-09 11:04:02 DEBUG Latest version is 6d35bd7947bad9e50772ab49bcc6c9c34979eeaa
2019-07-09 11:04:01 DEBUG Requesting URL via GET method: https://api.github.com/repos/Tautulli/Tautulli/commits/master
2019-07-09 11:04:01 INFO Retrieving latest version information from GitHub
2019-07-09 11:04:01 DEBUG Git output: origin/master
2019-07-09 11:04:01 DEBUG Trying to execute: "git rev-parse --abbrev-ref --symbolic-full-name @{u}" with shell in X:\PlexPy
2019-07-09 11:04:01 DEBUG Git output: 2635569e765e5817400ed1032a27bfc850242f6a
2019-07-09 11:04:01 DEBUG Trying to execute: "git rev-parse HEAD" with shell in X:\PlexPy
2019-07-09 11:04:01 INFO Checking if configuration upgrades are required...
2019-07-09 11:04:01 INFO Checking if the database upgrades are required...
2019-07-09 11:04:01 INFO Database File: X:\PlexPy\tautulli.db
2019-07-09 11:04:01 INFO Config File: X:\PlexPy\config.ini
2019-07-09 11:04:01 INFO Program Dir: X:\PlexPy
2019-07-09 11:04:01 INFO Python 2.7.14 (v2.7.14:84471935ed, Sep 16 2017, 20:19:30) [MSC v.1500 32 bit (Intel)]
2019-07-09 11:04:01 INFO America/New_York (UTC-0400)
2019-07-09 11:04:01 INFO Windows 10 (10.0.17763)
2019-07-09 11:04:01 INFO Starting Tautulli v2.1.29
2019-07-09 11:04:00 INFO Restarting Tautulli with ['X:\\Python27\\pythonw.exe', 'X:\\PlexPy\\Tautulli.py', '--nolaunch']
Incidentally, Iām still having the websocket issues that I detailed in this dead thread.
error: Your local changes to the following files would be overwritten by merge:
plexpy/__init__.py
Please commit your changes or stash them before you merge.
Either you modified the file plexpy/__init__.py or something else on your system modified the file. Git wonāt update the files if they have been modified.
In a recent update, something happened to the newsletter agent timing. I believe its been happening at least two weeks (including today). I have the config setting set to Fridays at 16:00. Its actually sent on Friday at 09:00. It has worked properly prior to recent change in behavior.
Is there a way to have Tautulliās newsletter display the Posters that have been chosen in Plex? I am seeing some random images in the display (see screenshot).
