I have a TBS 6902 dual DVB-S2 tuner PCie card that I have used for a year now in my HTPC with Plex, which worked beautifully. However I upgraded my HTPC mobo, CPU & new GPU recently and the tuner is no longer working. While Plex can see the tuner and I can get as far as scanning for channels, no channels are found.
I have checked drivers and all the usual stuff, installed the DVBDream software and was able to scan for and find the expected channels (Astra 28.2) with this software, so not a sat dish or tuner card issue per-se.
In the logs I see the following lines related to the attempted scan but don’t know what they mean.
Jan 10, 2023 08:49:26.402 [9864] WARN - [E] cannot initialize the tuning space
Jan 10, 2023 08:49:26.418 [9864] WARN - [E] CTVSStreamSource::LoadAndInitDriver. Failed to start device path @device:pnp:\?\pci#ven_544d&dev_6178&subsys_00026902&rev_00#6&380c5c7a&0&0038020b#{71985f48-1ca1-11d3-9cc8-00c04f7971e0}{978d88d4-ab27-49d8-b950-d513372a3b25}, type 1, frontend 0
Jan 10, 2023 08:49:26.418 [17508] WARN - [E] CTVSChannelScanner::Tune. Failed to tune to a transponder
Jan 10, 2023 08:49:26.418 [17508] WARN - [E] dvb_channel_scanner_t::do_scan_attempt. Tune failed for 12670,V,23000,23,S2,8PSK
Can anyone shed any light on this for me? Thanks all
