TV channel scan can not find any channels
I have a win 2012 R2 server with a Hauppauge WinTV-VR-2250. Running version 1.9.2.4285. When I try to setup the the live tv dvr functions Plex does not find any channels. I know the cable is good and the connection is good. The board works in other machines. The drivers are installed and Plex sees the board… but no TV channels.
Here is a log snipped that makes me wonder if this is a bug…
Oct 06, 2017 20:44:18.158 [3780] INFO - * find_device_by_path. searching for matching tuner with device path @device:pnp:\?\pci#ven_1131&dev_7164&subsys_88800070&rev_81#4&303ef882&0&00e3#{71985f48-1ca1-11d3-9cc8-00c04f7971e0}{06dad091-e58d-4e4d-9479-334aff773400}
Oct 06, 2017 20:44:18.158 [3780] INFO - * find_device_by_path. Found device index 0 for device path @device:pnp:\?\pci#ven_1131&dev_7164&subsys_88800070&rev_81#4&303ef882&0&00e3#{71985f48-1ca1-11d3-9cc8-00c04f7971e0}{06dad091-e58d-4e4d-9479-334aff773400}
Oct 06, 2017 20:44:18.158 [3780] INFO - * StartDevice() dwDeviceNo:0
Oct 06, 2017 20:44:18.200 [3780] INFO - * BDA Device Name: [Hauppauge WinTV-7164 BDA ATSC/QAM Tuner]
Oct 06, 2017 20:44:18.211 [3780] INFO - * add_filter (Hauppauge WinTV-7164 BDA ATSC/QAM Tuner)
Oct 06, 2017 20:44:18.211 [3780] INFO - * Tuner identity: vid (1131), pid (7164), subsys (88800070)
Oct 06, 2017 20:44:18.211 [3780] INFO - * ret_val: 0
Oct 06, 2017 20:44:18.211 [3780] WARN - [E] cannot create network provider
Oct 06, 2017 20:44:18.211 [3780] WARN - [E] cannot create network provider filter
Oct 06, 2017 20:44:18.220 [3780] WARN - [E] CTVSStreamSource::LoadAndInitDriver. Failed to start device path @device:pnp:\?\pci#ven_1131&dev_7164&subsys_88800070&rev_81#4&303ef882&0&00e3#{71985f48-1ca1-11d3-9cc8-00c04f7971e0}{06dad091-e58d-4e4d-9479-334aff773400}, type 16, frontend 0
Oct 06, 2017 20:44:18.221 [3776] WARN - [E] CTVSChannelScanner::Tune. Failed to tune to a transponder
Oct 06, 2017 20:44:18.221 [3776] WARN - [E] dvb_channel_scanner_t::do_scan. Tune failed for 57000,QAM256
Oct 06, 2017 20:44:18.221 [3776] INFO - * channel_scanner_t::scan_channels. Scanned 1 transponder out of 140. Channels found 0
Oct 06, 2017 20:44:18.271 [3780] INFO - * DeviceGetListEx_impl: Filter [Hauppauge WinTV-7164 BDA ATSC/QAM Tuner]
Oct 06, 2017 20:44:18.271 [3780] INFO - * DeviceGetListEx_impl: device instance path pci#ven_1131&dev_7164&subsys_88800070&rev_81#4&303ef882&0&00e3#
Oct 06, 2017 20:44:18.271 [3780] INFO - * DeviceGetListEx_impl: pDL->Count:2
Oct 06, 2017 20:44:18.271 [3780] INFO - * find_device_by_path. searching for matching tuner with device path @device:pnp:\?\pci#ven_1131&dev_7164&subsys_88800070&rev_81#4&303ef882&0&00e3#{71985f48-1ca1-11d3-9cc8-00c04f7971e0}{06dad091-e58d-4e4d-9479-334aff773400}
Oct 06, 2017 20:44:18.271 [3780] INFO - * find_device_by_path. Found device index 0 for device path @device:pnp:\?\pci#ven_1131&dev_7164&subsys_88800070&rev_81#4&303ef882&0&00e3#{71985f48-1ca1-11d3-9cc8-00c04f7971e0}{06dad091-e58d-4e4d-9479-334aff773400}
Oct 06, 2017 20:44:18.272 [3780] INFO - * StartDevice() dwDeviceNo:0
Oct 06, 2017 20:44:18.274 [3780] INFO - * BDA Device Name: [Hauppauge WinTV-7164 BDA ATSC/QAM Tuner]
Oct 06, 2017 20:44:18.275 [3780] INFO - * add_filter (Hauppauge WinTV-7164 BDA ATSC/QAM Tuner)
Oct 06, 2017 20:44:18.275 [3780] INFO - * Tuner identity: vid (1131), pid (7164), subsys (88800070)
Oct 06, 2017 20:44:18.275 [3780] INFO - * ret_val: 0
Any ideas?
You should search this forum. Seems to be a fairly common problem. Here’s a thread I found:
and another:
That was it. Thanks!
