Tennis Scanner
i have a lot of Tennis matches and would like them to be indexed in Plex
What I have is:
Tennis
   Australian Open
       2014
            Wawrinka-Djokovic-Final.ts
       2013
   Wimbledon
       2014
       2013
Can this be possible?
I tried various scanners but none of them did what  I need.
Thanks and regards
André
Your best bet would be to make a new section on your server and use the home movies type.
but then i have no subfolders...
and with the folders view i cannot add posters to the folders (i wanted seperate posters for each tournament)
or am i wrong?
or am i wrong?
You can display by folder in a home video library
What I have is:
Tennis
   Australian Open
       2014
       2013
   Wimbledon
       2014
       2013
Thanks and regards
André
FYI - you may wanna rename that match. That 2014 Wawrinka-Djokovic match was actually the semi :-D
I also need to be able to.make my own art for the folders.
FYI- after working with sports, fitness and training content that I had, it is best to create a library as a TV and Personal Media Shows agent- if you have a folder structure similar to what you posted. You will need to upload your own posters if you really want them but looks like when the library is complete.
If everything is posted in the same folder then it can simply be a Movies or Home Videos library
