Text size - Android head unit
I have Plexamp on my Android head unit (more like a tablet than radio) I find the text & buttons very small. See photo I have also tried Plexamp on my actual tablet, both about the same screen size, yet the text is larger. see comparison Could this be a scaling issue with my head unit? Can the problem be fixed?
Apart from this I love Plexamp, it’s now my daily driver, literally :smiley:
I think most likely related to DPI/scaling. If your unit has the ability, you should be able to set text size via Android settings, and the app will respect it.
We’ll also support Car View mode in landscape at some point.
Thanks for the reply. Unfortunately there is no easy way for me to increase text size. I also noticed that “Download Location” is missing from the head unit version here Not a major problem for me, just thought I’d let you know.
might be because the SD isn’t formatted as external storage?
