The ability to toggle an added home/friend user between local/remote access
I think it would be incredibly useful when adding a new user (let it be a home user or friend) to be able to have an option under user restrictions to select between local, remote, or both. So if you don’t want them using up ISP bandwidth, you can limit them to only being able to stream when they are on the same network.
So I guess it would be as simple as when they log in, the library/content only displays as available to them if they are local. If they are remote, the content can be greyed out or missing.
Just an idea :slight_smile:
Duplicate request. User level remote access restrictions
Crud, I couldn’t find that for the life of me, searching around. I do believe my comment to be a little more clear and with a little more context. The other person didn’t even upvote their own request as it asks you to. :slight_smile: lol
Would be helpful if there was a proper search function here.
