The Clearing (2023) The Clearing (TV Mini Series 2023) - IMDb
Episode metadata is showing from an old podcast instead of the new Disney plus show. I’ve unmatched/fix matched several times and there is only one option of the clearing to choose. All the other metadata of the series is correct.
The episodes show properly when searching and using plex’s streaming option.
Any ideas how to get these to show the right data?
This is once again a linking issue at the episode level. The show it self is matched properly as the 2023 version, but the episodes are matched with the 2019 version. This is not the case on TVDB itself.
Will probably take a while before someone fixes it. Mulligan hasn’t been fixed since it came out a month ago, so don’t hold your breath
I added the show to my server and also see the problem. Plex still shows 2019 episode information even when adding 2023 TVDB ID to folder name and specifying TVDB Aired episode ordering.
I came here today for exactly this problem. It appears to be matching episode titles and descriptions with those of a podcast with the same title.
Edit:
The Scanner and Agent for this library are both set to Plex TV Series
Changed on the show level as described to The Movie Database and this corrected the issue. I seem to remember that you could change the Agent during a Fix Match search. The drop down is there but there are no options. Thanks for this.
Yeah, I know I could switch, and I’ve done that in the past for some really stubborn shows, but these days I keep track of what’s not linked properly and usually report it here.
The Clearing (2023) now has correct episode information with either TMDB or TVDB (Aired) episode ordering. Refresh the metadata for the show to update your server.
Mulligan and Gremlins: Secrets of the Mogwai (mentioned in another thread) should update soon.
