The gpu transcoding sometime doesn't work on 1.18.7.2415
Server info
CPU: I5-8250U
GPU: UHD620
Software Version: 1.18.7.2415
when i use windows client or ios client, the gpu transcoding works fine.
but when i use xbox client or web, the gpu transcoding doesn’t work.
here is logs
Plex Media Server Logs_2020-02-14_20-16-09.zip (1.3 MB)
same strange behavior here!
Can you explain why you think the gpu transcoding is not working? Looking at your logs, it looks like it’s working to be.
Here it is when using Web (chrome).
Feb 14, 2020 19:45:22.111 [7604] DEBUG - TPU: hardware transcoding: final decoder: dxva2, final encoder: qsv
I didn’t see the Windows client, but for iOS I see that it doesn’t need to transcode the video, it’s a video stream copy.
i play the video(4k 10bit h.265) on ios and web, and set transcode to 1080p.
at the same time i check the server’s taskmanager.
ios device play the video, the server’s taskmanager shows that gpu load about 60%
web play the video, the server’s taskmanager shows that gpu load only 5%
Plex Media Server Logs_2020-02-15_21-46-32.zip (1.8 MB)
here is the log that windows client play the video
That’s odd. The playback for iOS doesn’t match what I saw in your previous logs. It showed no video transcoding so your GPU load should have been really small. I don’t know why you would see 60% load.
For your recent playback with Web, PMS shows it is using your GPU.
Feb 15, 2020 21:45:05.257 [6204] DEBUG - TPU: hardware transcoding: final decoder: dxva2, final encoder: qsv
Feb 15, 2020 21:45:05.258 [6204] DEBUG - Job running: EAE_ROOT=‘\?\D:\Document\Plex Media Server\Cache\Transcode\Sessions\EasyAudioEncoder’ FFMPEG_EXTERNAL_LIBS=‘\\?\D:\Document\Plex\ Media\ Server\Codecs\0bc617e-2965-windows-x86\’ X_PLEX_TOKEN=‘xxxxxxxxxxxxxxxxxxxx’ D:\Software\PlexMediaServer\Plex Transcoder.exe -codec:0 hevc -hwaccel:0 dxva2 -hwaccel_fallback_threshold:0 10 -hwaccel_output_format:0 dxva2_vld -codec:1 truehd_eae -eae_prefix:1 rwovbe7treowq4whp9tjbl28_ -ss 197 -analyzeduration 20000000 -probesize 20000000 -i “Y:\Media\电影\Ready Player One.mkv” -filter_complex [0:0]hwmap=derive_device=qsv[0];[0]scale_qsv=w=1920:h=802:format=nv12[1] -filter_complex “[0:1] aresample=async=1:ocl=‘7.1’:osr=48000[2]” -map [1] -codec:0 h264_qsv -b:0 5260k -maxrate:0 7014k -bufsize:0 14028k -forced_idr:0 1 -r:0 23.975999999999999 -map [2] -metadata:s:1 language=eng -codec:1 libopus -b:1 528k -map 0:9 -metadata:s:2 language=chi -codec:2 copy -map 0:t? -codec:t copy -f segment -segment_format matroska -segment_format_options live=1 -segment_time 1 -segment_header_filename header -segment_start_number 0 -segment_list http://127.0.0.1:32400/video/:/transcode/session/rwovbe7treowq4whp9tjbl28/378c090d-a9f3-4109-90f9-6802c5b401a2/seglist?X-Plex-Http-Pipeline=infinite -segment_list_type csv -segment_list_unfinished 1 -segment_list_size 5 -segment_list_separate_stream_times 1 -avoid_negative_ts disabled -map_metadata:g -1 -map_metadata:c -1 -map_chapters -1 chunk-%05d -start_at_zero -copyts -y -nostats -loglevel quiet -loglevel_plex error -progressurl http://127.0.0.1:32400/video/:/transcode/session/rwovbe7treowq4whp9tjbl28/378c090d-a9f3-4109-90f9-6802c5b401a2/progress
Can you check the dashboard instead of looking at the task manager?
