The "remote control" function stops working with the latest realse
Hi, since i upgraded to version 1.4.1.469-47a90f01, i have to restart home theater every day because it will not show up in my iphone app as a source to remote. have any one else the same problem?
Are you sure you are running OpenPHT not PHT?
The latest version of OpenPHT is 1.5.0.502-7563ca94 and can be found here
Thanks!
I do not probably run OpenPHT, did not even know about it. Up til now, i have used the built in update service. But everytime i scan for updates it says im up to date. will try this openPHT then. What is it by the way?
@maxter said:
Thanks!
Plex Inc have stopped developing Plex Home Theater, concentrating on a new product - Plex Media Player.
The Rasplex Team decided to take on the development of PHT as OpenPHT with Plex Inc’s blessing. There have been two releases to date which have fixed a number of long standing issues and also provided new functionality which users have been requesting for years. The Rasplex Team have provided fixes to PHT for the past couple of years which Plex incorporated in their releases.
Another release is being worked on at the moment to align code to allow a major release in the near future.
Regards
