Server Version#: 1.20.4.3517-ab5e1197c
Player Version#: Plex Web 4.43.4
I know I’ve had a topic many times, but I still haven’t found a solution for myself.
The latest version of everything is above. The Plex Server is set up properly. The plugins were also successfully installed manually (I attached the image), however, the installed plugins do not appear anywhere. Videos should have a plugin for Plex Online Content. Or was this only true for older versions, not for newer ones anymore?
Plugins : This was not a decision taken lightly, as they’ve been around for a long time, and we’ve had good times both writing and using them. But bluntly, hardly anyone uses them (less than 2% of users), the ancient protocol they use is a continued pain for clients to support, and if we were to build the feature again, we’d do it very differently in this day and age. For utility-type functionality, we love standalone apps like Tautulli and believe this is a better approach. But don’t panic—while the Plugin Directory will soon be gone, you can still manually install plugins for the foreseeable future.
You might still be able to install them, but they will no longer show in the main menu nor play any content.
