There is a problem with iOS plexamp version 4.5.2
If random shuffle on while playing music and move to the back of a few songs on the list, Ui will not respond at some point and only the music will play.
The playback time remains the same in seconds
The name of the song doesn’t change and it doesn’t work properly.
To solve this problem, you must shut down the app completely and then turn it back on.
Very frequent and very inconvenient to use
Like below screenshot… music is playing but ui is stucked
After killing and restarting the app, can you upload Plexamp logs?
Just tried to reproduce over here without luck.
Plexamp-Logs-2022-11-05-1.zip (367.4 KB)
Thank you for the logs; I think I see the issue.
Same issue here on Android once updating to 4.5.2. I am noticing when I play a new track and the UI freezes, playback stops after two songs.
If it’s what I think it is, will be fixed in the next release!
Thanks for the reports.
