TheTVDB agent on the Plex Media Server is missing an entry for the Slovenian language. TheTVDB.com site does support it under "Slovenski" and the language ID is 30. Thanks.
Hi!
I have added the Slovenian language to TheTVDB agent. The updated agent will be downloaded by your PMS automatically.
Hi!
Great!
But I think you've missed a location. Shouldn't you have you included the language code in line 93 as well?
Great!
You are right, sorry about that! I've made the change and pushed out another update.
Hey
how can i add language to TheTVDB agent ??
