themovieDB agent - (un)supported languages (in pref)
As i'm new on this forum (albeit using PLEX for many years) i'd like to say 'hello' to everyone.
I found out that in preferences of themovieDB (The Movie Database) agent you can't choose 'Poland' as a prefered country for metadata. Seems like a simple omission as themovieDB supports polish language and content as well as this locale is mentioned internally in the agent code.
As a workaround I tried to edit agent bundle (namely __init__.py and DefaultPref.json files) adding Poland on the language/country list. To my surprise the first time I restarted PlexServer the content of aforementioned files got overwritten by previous values. So i edited them once again and locked the bundle in file system.
Neither the less themovieDB agent seems to ignore 'pl' locale and still uses 'en' as default:
(from com.plexapp.agents.themoviedb.log):
DEBUG (networking:167) - Fetching 'https://api.themoviedb.org/3/movie/75015?api_key=a3dc111e66105f6387e99393813ae4d5&append_to_response=releases,casts&language=en' from the HTTP cache
How could it be corrected in a proper way - should it be issued as a bug to PLEX or agents gets another route to be corrected?
regards
