TheTVDB not working
From some months now, TheTVDB no longer working like it should.
I’ve already opened a discussion in last December but I have not got a solution.
It looks like this my library:
Missing covers, missing titles, missing descriptions
Solution?
The first place we start is usually at file names and structures within a TV Show Library - that need to be in compliance with Plex Guidelines. That’s usually where we end these discussions because most people find out that’s all they needed to do.
https://support.plex.tv/hc/en-us/categories/200028098-Media-Preparation
Recently the discussions branch off into the random and missing status of TVDB’s presence on the internet, but that seems to be slowly getting better.
So… let’s start with your naming and structuring (provide some proof - a screenshot of your library structures in Windows Explorer will do) and we’ll take it from there.
In RARE cases more serious problems exist in the database, but we’ll eventually get there if that’s necessary.
The structure with which I named the files is:
Anime/Anime Name/Season XX/Anime Name - sXXeYY - Episode Title.ext
For example:
and here’s how it looks on Plex:
Well… my Italian is rusty (I can speak English with a West Virginia/Italian Accent - like Peter Griffin), but it looks like you have a pretty good name structure. Your listing seems to have missed the mark unless what you’re file name says matches what I’m seeing - and the only one currently in this thread that can answer that would be you:
http://thetvdb.com/?tab=season&seriesid=72454&seasonid=4166&lid=7
Also note that when you view TVDB in Italian it may be totally different than what I’m seeing in English. The bottom line is to match what you see at TVDB.
Another possible area to explore would be your TV Show Library Location.
PLEX/ANIME/ <---- TV Show Library aimed here
…Detective Conan/
would be good
PLEX/ <----- TV Show Library aimed here
…ANIME/
…Detective Conan/
would be bad
in this way:
PLEX/ It contains all files
……ANIME/ It contains the anime
…………Anime 1
…………Anime 2
……SERIE TV It contains the TV series
…………TV Series 1
…………TV Series 2
……FILM It contains the movies
…………Film 1
…………Film 2
“ANIME” has its own library on Plex, “SERIE TV” has a library on Plex etc.
It’s okay?
Maybe OK. If I’m understanding you:
An Anime Library:
Plex/Anime/ <---- TV Show Library aimed here
…Anime Show/
…Season xx/
…Anime Show - SxxExx.xxx
A TV Show Library:
Plex/Serie TV/ <---- TV Show Library aimed here
…TV Series 1/
…Season xx/
…TV Series 1 - SxxExx.xxx
A Movie Library:
Plex/Film/ <---- Movie Library aimed here
…Film 1 (YEAR) [extra info].xxx
or
…Film 1 (YEAR) [extra info]/
(you can nest movies in folders if you want to - not so with TV Shows)
If it’s like that - very good.
My library is organized in exactly this way
OK.
Then the issue is you have to name your files as they are listed at TVDB. No other listings will work unless you are using a special ‘Anime’ Agent that I am unaware of.
http://thetvdb.com/?tab=series&id=72454&lid=7
Detective Conan - as an example.
The file names are those of TheTVDB, i use FileBot to rename files.
Attach the log files gathered here to your next post:
Here the log files
OK - paging Drs. Kildare and Welby - @astrofisher , @OttoKerner …
That looks like some pretty good naming to me. Let’s see what the M.D.s come up with.
I took a look. I didn’t see a new item added to the library that could be followed through process of matching and grabbing metadata.
I did see server errors in thetvdb.log:
IOError: [Errno 13] Permission denied: u’\\?\C:\Users\Feliziani\AppData\Local\Plex Media Server\Plug-in Support\Caches\com.plexapp.agents.thetvdb\HTTP.system\CacheInfo’
I would try clearing thetvdb cache.
Clearing Plugin/Channel/Agent HTTP Caches
After clearing the cache I update the library?
I would try Refresh.
No, it does not work … on some series and some anime this problem there is always
