TheTVDB
Hey!
Since a couple days ago i sometimes get problems with the meta data for episodes names. From the 3 episodes i got last night i only got 2 episode names, the last one didn't get any episode name.
My sabnzbd & sickbeard are configurated to automaticly rename to proper names & folders: "Season 2\Chicago Fire - S02E10 - Not Like This.mp4" etc.
When i use a force scan it works all of a sudden & it gets all the metadata now. If i have to do this all the time when i get new episodes...
Im using 0.9.8.17 (also try the newer version, but then my Trakttv plugin doesn't work anymore + same metadata problem.)
Im not sure where i can find the correct log for this problem. Do i need to search in the scanner or thetvdb log?
Both logs would be helpful, but at the very least the com.plexapp.agents.tvdb.log from your PMS Plugin Logs directory would be helpful.
