Third party commentary in recorded shows?
Server Version#:
Tuner Make/Model: Hauppauge Quad tuner
Guide/Lineup name:
Using XMLTV?: no
Channel number/Name:
I recorded Bob Hearts Abishola just to see how well plex does at detecting and removing commercials. (Very well BTW.) However during playback, I’m hearing a third party, male voice describe events as if for a sight impaired person. In looking at the settings I don’t see any option for this feature. Anyone else notice this? Any way to disable this?
If the show was recorded w/ multiple audio tracks, you should be able to pick one.
It appears that my Sony Bravia has an auto SAP setting. Since I cannot disable it on the TV I’m not sure plex can do anything about it since I suspect it is embedded in the digital signal.
Where would one pick an audio Track?
You can usually manually select from the available tracks on the actual movie page or change the selection during playback.
Thanks but this is a dvr show, and those options aren’t available…
Why can’t it be disabled?
I would have to disable the external speakers (7.1) surround to do so.
