There was an unexpected error
Please visit our forums if you continue to experience problems
What ERROR? You hit a problem trying to download and your developers are so poor that they can’t point you in the right direction except to go to the forum where PLEX doesn’t respond but then closes the post after 3 months! You people are amazing, NOT!
Windows 11 trying to download from from iMac. Always used to work…
The plex community helps a large number of users, if you can point to the previous post, we can assist in both why it was ignored (often posts without enough context are just ignored, as often its hard to get the needed details from the user) and to assist in resolving your issue.
Server Version#: 1.32.5.7349
Player Version#: 9.28.0.3162 (75a3f28) on a Pixel 7 Pro
I’m regularly downloading content from my Plex server to my mobile phone, so that I can watch it while commuting. However, I lately more often than not encounter the annoying error message
"There was an error downloading this file. Swipe to remove or tap to retry."
Obviously retrying is useless, it doesn’t work no matter how often I try. But I am wondering if there is a somewhere an entry in a log file that would actually explain what the problem is so that I can fix it. Most likely it has something to do with the file format, but without details, what should I try to fix?
Me too
last visit
3 months later
Closed on Nov 23, 2023
So why that post wasn’t answered I can not tell, but can tell you that if I had seen it, my answer would be the same as you got now…We need server logs
