Tidal artists not being Added to Plex
Server Version#: 1.28.2.6106
Player Version#: 4.87.2
I just got a subscription through Plex, my first issue is that I cannot access Tidal music at all through app.plex.tv - it only works if I try to access it locally. When I try to get the artists I’ve added with Tidal to Plex using the “add to Plex” option, if I select all artists (300ish) and try to add them all at once, it’ll add a few then stop. Seems like I can only add them in chunks of maybe 5-10 at a time? When selecting all artists starting with A etc I can add most of them, but then the last few seem to get stuck and the logs are indicating a timeout somewhere.
I wouldn’t bother, but this seems to be the only easy way to create playlists via Tidal music - doing it through Tidal is a nightmare.
This integration needs some work… What’s taking me 2 days now should only take a couple clicks…
Adding artists to Plex is extremely slow, and half the time artists get missed entirely if I choose 2-3.
Artwork for some of the artists doesn’t show through the Tidal tab (nothing Plex can do I assume), but after adding it to Plex, I guess because of the Plex Music scanner, some artwork gets added for the artists it does add. Seems be to very choosy with the artists it’ll let you add to Plex though. Ben Moody for instance, is found on Tidal, I’ve personally had mp3’s of his music in Plex and it matched fine in the past and yet Plex refuses to add it, there are a couple others it does this with too (Meshuggah).
There’s also an issue of artists somehow being matched incorrectly? I don’t see how this happens when it’s all coming directly through Tidal, so there’s no ID3’s or metadata for me to mess up…
Can someone please look into this? I can provide logs if necessary.
Normally I wouldn’t care and just use Tidal through the Tidal library, but the missing artwork is bugging me.
I’ve confirmed that there’s no network issue on my end as Tidal only seems be to accessible via accessing Plex locally and not the web app for whatever reason.
Correction For some reason Meshuggah got matched to AstroPilot???
London Philharmonic Orchestra matched to César Franck…
