Missing music from Tidal
I am trying the Tidal integration. Have found some albums missing from Tidal on Plex, but they’re available on the Tidal app. Is there a place I can request the missing albums besides the forums?
Thanks!
I have the same issue, for example I wold like to add “The Rolling Stones” album from Tidal:
But in Plex some tracks are not visible:
Is there a solution for this?
Thanks!
If only we here was a way to report missing tracks.
Is the Tidal integration still important to Plex inc?
It’s a long time issue. Follow this thread
Thanks Javier. I noticed the issue, but the lack of recent support on the issue, is disheartening.
Also I’m worried I just switched full to Tidal and Plex as my main source of Music listening, And I prefer Plexamp instead of the Tidal app.
Adding my voice here as well. Like @ecr80, I switched to Plex + Tidal as my main music source, and while the integration works decently, there are quite a few annoying issues, with this missing songs issue being the main one.
I have about 5 or so tracks saved to My Tidal that show up on Plex if I go to Music On Tidal, but that throw a bunch of errors on the log when I try to add them to my server:
All of the errors above are from an attempt to add a single Tidal song to my Plex server. There are also 1 or 2 tracks from Tidal that simply do not show up on Plex at all.
It would be good to hear back from Plex itself on this matter, given that there is no way of reaching them directly via email.
so yesterday they finally release the complete version of Smashing Pumpkins new album, and it still not showing on Plex at all.
https://tidal.com/browse/album/280733101
