A few Tidal integration suggestions!
Tidal gives listeners “Mixes for You” playlists based on what you like on Tidal. Could those playlists be added to Plex? Also, could the integration play the song from the Plex server if you have it in your library instead of streamed on Plex? That would be incredible! In fact, any playlist saved on Plex could you have the local server file play instead of Tidal streaming? Or at least make it an option to chose when saving the playlist?
When you save a Tidal track to your library : Don’t sort it as Various Artists if it’s a completion album. I know this is an annoying flaw brought over from our libraries, but it really needs to be fixed. (Don’t ever sort songs as VARIOUS ARTISTS but instead the artist) You can sort the Albums that way, but never the tracks.
THANKS! Enjoying Plex with Tidal!
