Too many channels
In the UK, created a new DVR using a HDHomeRun CONNECT QUATRO.
I selected only 25 channels from Freeview. In the DVR Guide page it has 42 channels ?!?!?
How do I fix this ?
For example, I have removed BBC 1 as I only want BBC 1 HD.
Hello, just click on the channels enabled and you should be able to select which ones are enabled and which ones aren’t. If that doesn’t work you can always go to the hdhomerun website which is my hdhomerun just do a Google search and you can disable them there then just rescan in Plex.
Even easier. if you are using HDHomerRun disable them first in the HDHomeRun lineup and they won’t appear in Plex DVR.
Ah great thanks ! solved the issue :grinning:
