I have a HDHomerun and a Quarto HDHomrun box. After I setup the HDHomerun settings I went in to remove the channels I do not want. Example, the non-english channels.
Now the HDHomerun player shows only the channels I want, however in Plex TV guide, it shows all 97 channels enabled. On the HDHomerun it only shows the 47 channels I want.
When I try and edit the 97 channels in the Plex Live/DVR settings it says 47 in grey but 97 enabled. But when I click it, it only shows 47 but when I goto the guide it shows all 97 channels.
Is there a way to get the guide to only show the 47 channels?
I ALSO USE HDHOMERUN. YES, I KNOW CAPS IS LIKE SHOUTING BUT I AM FRIGGING ANGRY AT POOR HELP. i HAVE NOT BEEN ABLE TO FIND A WAY TO DISABLE OR REMOVE CHANNELS IN PLEX. I FINALLY FOUND A HELP DOCUMENT EXPLAINING HOW TO REMOVE CHANNELS, BUT IT REFERRED TO A CHANNEL MENU IN THE SIDEBAR AND THERE IS NO CHANNEL SETTING IN THE SIDEBAR. I HAVE WASTED THREE HOURS TRYING TO FIND HOW TO REMOVE CHANNELS AND STILL CANNOT FIND WHAT MUST BE A COMMON REQUEST.
Oh btw. I did not write that message in all caps. Your referring to someone else. This is my first post. But I did not write that message in all caps. I think your referring to vance302.
You suggestions worked - the feature I needed was buried too deep into other menus, but I was able to determine my HD-homerun showed 94 channels, but signals for only 54 from Orlando were good enough to show up in Plex, and I was able to disable a bunch of ad driven channels and hispanic and religious channels, and now down to 32 channels that I want.
