Toshiba x300 Performace
Hi folks,
I have the opportunity to get a Toshiba X300 Performace 8Tb disk at a very…VERY… good price to add to my PMS, but I have my doubts about having this disk running 7x24, because it’s not NAS… any opinions or owners of this disk here?
From the Toshiba specs page
Reliability
MTTF
600,000 hours
Unrecoverable error rate
1 per 10¹⁴ bits read
Compared to a WD Red Pro
Reliability/Data Integrity
Load/unload cycles 600,000 600,000 600,000 600,000 600,000
Non-recoverable errors per bits read <10 in 10^14 <10 in 10^14
<10 in 10^14 <10 in 10^14 <10 in 10^14
MTBF (hours) 1,000,000 1,000,000 1,000,000 1,000,000 1,000,000
Workload Rate (TB/year) 300 300 300 300 300
Limited warranty (years) 5 5
Compared to Enterprise drive
Reliability
Error rate (non-recoverable, bits read) 1 in 10^15 ←
Load/Unload cycles (at 40ºC) 600,000 ←
Availability (hrs/day x days/wk) 24x7 ←
MTBF
 (M hours) 2.5 ←
Annualized Failure Rate
 (AFR) 0.35% ←
Warranty (yrs) 5
Personally, I opted for the UltraStar HUH721212ALE604 (other capacities available)
  1. Longer MTBF (2.5M hours)
  2. Lower single bit read failure (1 / 10^15 )
Enterprise drives are rated to take a pounding where the Desktop/Workstation Toshiba is not.
If you keep the Toshiba properly cooled (remember, drives don’t like getting overheated), and at a constant (on) temperature with OS on , it’ll be the most stable it can be.
