Can you enable the ability to add tracks played from Tidal (but not added to the library) into the play history. For example if you play a Tidal playlist there is no record of what was played if you want to go back and check out an artist from the PL you have go back through the playlist itself rather than look in the history.
The HISTORY is (sadly) per-server. If you switch over to TIDAL as a source it should show you recently played artists, at least.
