Trailer nicht verfügbar
Hallo, Ich brauche HILFE
Trotz vieler Anleitungen zu diesen Thema habe ich immer noch dieses Problem.
Meine Hardware:
ATV 3  IOS 6.01
Synology  412+ DSM 4.3-3775
Plex Media Server 0.9.8.10.215-020456b
PlexConnect 0.2.6 danach update bei GithubPhyton 2.7.5-6
Certifikate auf dem Apple TV
Settings.cfg
[PlexConnect]
logpath = ../../var
enable_dnsserver = True
ip_webserver = 192.168.2.4
prevent_atv_update = True
enable_plexconnect_autodetect = True
port_pms = 32400
port_webserver = 81
ip_plexconnect = 192.168.2.4
certfile = /usr/local/plexconnect/share/PlexConnect/assets/certificates/trailers.pem
ip_dnsmaster = 192.168.2.1
loglevel = High
ip_pms = 192.168.2.4
enable_plexgdm = True
port_ssl = 443
enable_webserver_ssl = True
port_dnsserver = 53
Logfile
19:46:56 PlexConnect: started: 19:46:56
19:46:56 Settings: getsetting enable_plexconnect_autodetect=True
19:46:56 PlexConnect: IP_self: 192.168.2.4
19:46:56 Settings: getsetting enable_dnsserver=True
19:46:56 DNSServer: started: 19:46:56
19:46:56 Settings: getsetting port_dnsserver=53
19:46:56 Settings: getsetting ip_dnsmaster=192.168.2.1
19:46:56 Settings: getsetting prevent_atv_update=True
19:46:56 DNSServer: ***
19:46:56 DNSServer: DNSServer: Serving DNS on 192.168.2.4 port 53.
19:46:56 DNSServer: intercept: ['trailers.apple.com', 'atv.plexconnect'] => 192.168.2.4
19:46:56 DNSServer: restrain: ['mesu.apple.com', 'appldnld.apple.com', 'appldnld.apple.com.edgesuite.net'] => 127.0.0.1
19:46:56 DNSServer: forward other to higher level DNS: 192.168.2.1
19:46:56 WebServer: started: 19:46:56
19:46:56 Settings: getsetting port_webserver=81
19:46:56 WebServer: ***
19:46:56 WebServer: WebServer: Serving HTTP on 192.168.2.4 port 81.
19:46:56 ATVSettings: init class CATVSettings
19:46:56 ATVSettings: load settings
19:46:57 DNSServer: DNS request received!
19:46:57 DNSServer: Source: ('192.168.2.7', 60937)
19:46:57 DNSServer: Domain: setup.icloud.com
19:46:57 DNSServer: ***forward request
19:46:57 DNSServer: -> DNS response from higher level
19:46:57 Settings: getsetting enable_webserver_ssl=True
19:46:57 WebServer: started: 19:46:57
19:46:57 Settings: getsetting port_ssl=443
19:46:57 Settings: getsetting certfile=/usr/local/plexconnect/share/PlexConnect/assets/certificates/trailers.pem
19:46:57 WebServer: ***
19:46:57 WebServer: WebServer: Serving HTTPS on 192.168.2.4 port 443.
19:46:57 DNSServer: Source: ('192.168.2.7', 63489)
19:46:57 DNSServer: Domain: p21-buy.itunes.apple.com
19:46:59 DNSServer: DNS request received!
19:46:59 DNSServer: Source: ('192.168.2.7', 62473)
19:46:59 DNSServer: Domain: init.itunes.apple.com
19:46:59 DNSServer: ***forward request
19:46:59 DNSServer: -> DNS response from higher level
19:46:59 DNSServer: Source: ('192.168.2.7', 53709)
19:46:59 DNSServer: Domain: time.apple.com
19:46:59 DNSServer: Source: ('192.168.2.7', 54953)
19:46:59 DNSServer: Domain: upp.itunes.apple.com
19:46:59 DNSServer: Source: ('192.168.2.7', 62663)
19:46:59 DNSServer: Domain: bookkeeper.itunes.apple.com
19:47:00 DNSServer: -> DNS response from higher level
19:47:00 DNSServer: DNS request received!
19:47:00 DNSServer: Source: ('192.168.2.7', 61914)
19:47:00 DNSServer: Domain: itunes.apple.com
19:47:00 DNSServer: ***forward request
19:47:00 DNSServer: Source: ('192.168.2.7', 55733)
19:47:00 DNSServer: Domain: xp.apple.com
19:47:00 DNSServer: Source: ('192.168.2.7', 49183)
19:47:00 DNSServer: Domain: EVSecure-ocsp.verisign.com
19:47:00 DNSServer: Source: ('192.168.2.7', 57150)
19:47:00 DNSServer: Domain: www.apple.com
19:47:03 DNSServer: DNS request received!
19:47:03 DNSServer: Source: ('192.168.2.7', 51321)
19:47:03 DNSServer: Domain: pd-nk.itunes.apple.com
19:47:03 DNSServer: ***forward request
19:47:03 DNSServer: -> DNS response from higher level
19:47:03 DNSServer: Source: ('192.168.2.7', 62277)
19:47:03 DNSServer: Domain: configuration.apple.com
19:47:07 DNSServer: DNS request received!
19:47:07 DNSServer: Source: ('192.168.2.7', 64373)
19:47:07 DNSServer: Domain: se.itunes.apple.com
19:47:07 DNSServer: ***forward request
19:47:07 DNSServer: -> DNS response from higher level
19:47:07 DNSServer: Source: ('192.168.2.7', 61019)
19:47:07 DNSServer: Domain: e3191.dscc.akamaiedge.net
19:47:07 DNSServer: Source: ('192.168.2.7', 52855)
19:47:07 DNSServer: Domain: www.apple.com
19:47:07 DNSServer: Source: ('192.168.2.7', 51273)
19:47:07 DNSServer: Domain: p06-keyvalueservice.icloud.com
19:47:08 DNSServer: -> DNS response from higher level
19:47:10 DNSServer: DNS request received!
19:47:10 DNSServer: Source: ('192.168.2.7', 64857)
19:47:10 DNSServer: Domain: p06-streams.icloud.com
19:47:10 DNSServer: ***forward request
19:47:10 DNSServer: -> DNS response from higher level
19:47:10 DNSServer: Source: ('192.168.2.7', 56027)
19:47:10 DNSServer: Domain: p06-sharedstreams.icloud.com
19:47:10 DNSServer: Source: ('192.168.2.7', 57217)
19:47:10 DNSServer: Domain: itunes.apple.com
19:47:10 DNSServer: Source: ('192.168.2.7', 52363)
19:47:10 DNSServer: Domain: p21-buy.itunes.apple.com
19:47:11 DNSServer: DNS request received!
19:47:11 DNSServer: Source: ('192.168.2.7', 65185)
19:47:11 DNSServer: Domain: init.ess.apple.com
19:47:11 DNSServer: ***forward request
19:47:11 DNSServer: -> DNS response from higher level
19:47:12 DNSServer: DNS request received!
19:47:12 DNSServer: Source: ('192.168.2.7', 57451)
19:47:12 DNSServer: Domain: SVRSecure-G3-aia.verisign.com
19:47:12 DNSServer: ***forward request
19:47:12 DNSServer: -> DNS response from higher level
19:47:19 DNSServer: DNS request received!
19:47:19 DNSServer: Source: ('192.168.2.7', 58909)
19:47:19 DNSServer: Domain: init-p01st.push.apple.com
19:47:19 DNSServer: ***forward request
19:47:20 DNSServer: -> DNS response from higher level
19:47:20 DNSServer: DNS request received!
19:47:20 DNSServer: Source: ('192.168.2.7', 53183)
19:47:20 DNSServer: Domain: 45-courier.push.apple.com
19:47:20 DNSServer: ***forward request
19:48:56 DNSServer: DNS request received!
19:48:56 DNSServer: Source: ('192.168.2.7', 51494)
19:48:56 DNSServer: Domain: bookkeeper.itunes.apple.com
19:48:56 DNSServer: ***forward request
19:48:56 DNSServer: -> DNS response from higher level
19:48:57 DNSServer: DNS request received!
19:48:57 DNSServer: Source: ('192.168.2.7', 57570)
19:48:57 DNSServer: Domain: upp.itunes.apple.com
19:48:57 DNSServer: ***forward request
19:48:57 DNSServer: -> DNS response from higher level
20:02:03 DNSServer: DNS request received!
20:02:03 DNSServer: Source: ('192.168.2.7', 51691)
20:02:03 DNSServer: Domain: a2.mzstatic.com
20:02:03 DNSServer: ***forward request
20:02:03 DNSServer: -> DNS response from higher level
20:02:03 DNSServer: Source: ('192.168.2.7', 54000)
20:02:03 DNSServer: Domain: p21-buy.itunes.apple.com.akadns.net
20:02:03 DNSServer: Source: ('192.168.2.7', 63685)
20:02:03 DNSServer: Domain: a1.mzstatic.com
20:02:04 DNSServer: -> DNS response from higher level
20:02:04 DNSServer: DNS request received!
20:02:04 DNSServer: Source: ('192.168.2.7', 63065)
20:02:04 DNSServer: Domain: a3.mzstatic.com
20:02:04 DNSServer: ***forward request
20:02:04 DNSServer: Source: ('192.168.2.7', 55297)
20:02:04 DNSServer: Domain: a5.mzstatic.com
20:02:08 DNSServer: DNS request received!
20:02:08 DNSServer: Source: ('192.168.2.7', 63851)
20:02:08 DNSServer: Domain: trailers.apple.com
20:02:08 DNSServer: ***intercept request
20:02:08 DNSServer: -> DNS response: 192.168.2.4
20:02:08 WebServer: http request header:
Host: trailers.apple.com
Accept-Encoding: gzip, deflate
Accept: */*
Accept-Language: de;q=0.9, en;q=0.8
Cookie: s_vi=[CS]v1|293008F085012631-4000160800009F69[CE]
Connection: keep-alive
X-Apple-TV-Resolution: 1080
X-Apple-TV-Version: 6.0.1
User-Agent: iTunes-AppleTV/6.0.1 (3; 8GB; dt:12)
20:02:08 WebServer: http request path:
/appletv/us/js/application.js
20:02:08 Localize: aTVLanguage: de
20:02:08 WebServer: pms address:
20:02:08 WebServer: cleaned path:
20:02:08 WebServer: PlexConnect options:
{'aTVLanguage': 'de', 'aTVAddress': '192.168.2.7'}
20:02:08 WebServer: additional arguments:
20:02:08 WebServer: serving  /volume1/@appstore/plexconnect/share/PlexConnect/assets/js/application.js
20:02:08 DNSServer: Source: ('192.168.2.7', 57551)
20:02:08 DNSServer: Domain: atv.plexconnect
20:02:15 DNSServer: DNS request received!
20:02:15 DNSServer: Source: ('192.168.2.7', 54504)
20:02:15 DNSServer: Domain: neulion-a.akamaihd.net
20:02:15 DNSServer: ***forward request
20:02:16 DNSServer: -> DNS response from higher level
20:02:17 DNSServer: DNS request received!
20:02:17 DNSServer: Source: ('192.168.2.7', 59160)
20:02:17 DNSServer: Domain: securemetrics.apple.com
20:02:17 DNSServer: ***forward request
20:02:17 DNSServer: -> DNS response from higher level
20:02:17 DNSServer: Source: ('192.168.2.7', 52165)
20:02:17 DNSServer: Domain: gamecenter.nhl.com
20:02:17 DNSServer: Source: ('192.168.2.7', 52680)
20:02:17 DNSServer: Domain: EVSecure-ocsp.verisign.com
20:02:17 DNSServer: Source: ('192.168.2.7', 51684)
20:02:17 DNSServer: Domain: EVIntl-ocsp.verisign.com
20:18:07 DNSServer: DNS request received!
20:18:07 DNSServer: Source: ('192.168.2.7', 62638)
20:18:07 DNSServer: Domain: p21-buy.itunes.apple.com.akadns.net
20:18:07 DNSServer: ***forward request
20:18:07 DNSServer: -> DNS response from higher level
20:18:08 DNSServer: DNS request received!
20:18:08 DNSServer: Source: ('192.168.2.7', 57897)
20:18:08 DNSServer: Domain: neulion-a.akamaihd.net
20:18:08 DNSServer: ***forward request
20:18:08 DNSServer: -> DNS response from higher level
20:18:10 DNSServer: DNS request received!
20:18:10 DNSServer: Source: ('192.168.2.7', 57323)
20:18:10 DNSServer: Domain: gamecenter.nhl.com
20:18:10 DNSServer: ***forward request
20:18:10 DNSServer: -> DNS response from higher level
20:18:41 DNSServer: DNS request received!
20:18:41 DNSServer: Source: ('192.168.2.7', 52734)
20:18:41 DNSServer: Domain: trailers.apple.com
20:18:41 DNSServer: ***intercept request
20:18:41 DNSServer: -> DNS response: 192.168.2.4
20:18:41 WebServer: http request header:
Accept: */*
20:18:41 WebServer: http request path:
20:18:41 Localize: aTVLanguage: de
20:18:41 WebServer: pms address:
20:18:41 WebServer: cleaned path:
20:18:41 WebServer: PlexConnect options:
20:18:41 WebServer: additional arguments:
20:18:41 WebServer: serving  /volume1/@appstore/plexconnect/share/PlexConnect/assets/js/application.js
20:18:41 DNSServer: Source: ('192.168.2.7', 64650)
20:18:41 DNSServer: Domain: atv.plexconnect
20:20:22 DNSServer: DNS request received!
20:20:22 DNSServer: Source: ('192.168.2.7', 51521)
20:20:22 DNSServer: Domain: metrics.mzstatic.com
20:20:22 DNSServer: ***forward request
20:20:22 DNSServer: -> DNS response from higher level
20:21:33 DNSServer: DNS request received!
20:21:33 DNSServer: Source: ('192.168.2.7', 60732)
20:21:33 DNSServer: Domain: e905.b.akamaiedge.net
20:21:33 DNSServer: ***forward request
20:21:33 DNSServer: -> DNS response from higher level
20:22:54 DNSServer: DNS request received!
20:22:54 DNSServer: Source: ('192.168.2.7', 60118)
20:22:54 DNSServer: Domain: e905.b.akamaiedge.net
20:22:54 DNSServer: ***forward request
20:22:54 DNSServer: -> DNS response from higher level
20:28:44 DNSServer: DNS request received!
20:28:44 DNSServer: Source: ('192.168.2.7', 54633)
20:28:44 DNSServer: Domain: e905.b.akamaiedge.net
20:28:44 DNSServer: ***forward request
20:28:44 DNSServer: -> DNS response from higher level
20:30:10 DNSServer: DNS request received!
20:30:10 DNSServer: Source: ('192.168.2.7', 63941)
20:30:10 DNSServer: Domain: e905.b.akamaiedge.net
20:30:10 DNSServer: ***forward request
20:30:10 DNSServer: -> DNS response from higher level
20:32:00 DNSServer: DNS request received!
20:32:00 DNSServer: Source: ('192.168.2.7', 52402)
20:32:00 DNSServer: Domain: e905.b.akamaiedge.net
20:32:00 DNSServer: ***forward request
20:32:00 DNSServer: -> DNS response from higher level
21:12:30 DNSServer: DNS request received!
21:12:30 DNSServer: Source: ('192.168.2.7', 61664)
21:12:30 DNSServer: Domain: e905.b.akamaiedge.net
21:12:30 DNSServer: ***forward request
21:12:30 DNSServer: -> DNS response from higher level
Was mache ich falsch
Bitte um Hilfe
>> port_webserver = 81
Das ist nicht gut... aTV schickt Request an Port 80. "Port Forwarding" gesetzt?
>> PlexConnect 0.2.6
Was ist denn das? Wo kommt diese Nummer her?
> PlexConnect 0.2.6
Das zeigt mir die Synology an als Version von PlexxConnect
Wo Stelle ich dies ein.
Also nein... Ich habe auch keine Ahnung, habe keine Synology.
Aber ich weiss, dass aTV einen "normalen" http-Request schickt. Und der kommt auf Port 80 an.
Lösung A: PlexConnect zurueck auf Port 80 konfigurieren? Geht vermutlich nicht, da hier schon der NAS WebClient hängt?
Dann bleibt wohl nur der Thread im englischsprachigen Teil. Etwas lang inzwischen, aber ganz am Anfang ist glaub ich eine recht gute Anleitung:
http://forums.plexapp.com/index.php/topic/72356-plexconnect-on-synology/
Sorry.
Zusatzfrage... welche Anleitungen hast du gelesen?
Den Port 80 kann ich nicht nehmen wegen der NAS.
Den Thread kenn ich schon, aber totzdem danke
Aber da steht doch alles, mit Definition von VirtualHost 80/81 usw. Das waere, was ich als"Port Forwarding" bezeichne...
Habe ich auch eingestellt, aber leider ohne Erfolg.
Danke :rolleyes:
Hat sich erledigt, es geht.
Habe den Apache Webserver Port geändert, :D :D :D :D :D :D :D :D
Glueckwunsch!
