I could not find anything about this anywhere and don't know if you are aware of this issue with special episodes.
Short version: Seasons with special episodes will give an error on the Apple TV and won't list the season/show.
Long version:
Your ATV model (2 or 3) and firmware version (found under the ATV settings > general > about > Apple TV software):
ATV3, firmware 5.3 (6105)
The DNS server set on the ATV (found under the ATV settings > general > network > DNS):
10.0.1.6
The device and operating system (including version number) that PlexConnect is installed on:
Intel® Core™2 Quad CPU Q6600 @ 2.40GHz × 4
Ubuntu 12.04 LTS
The local IP address of the device that PlexConnect is installed on:
10.0.1.6
The device and operating system (including version number) that the Plex media server (PMS) is installed on:
Same as above (PlexConnect)
The local IP address of the device that the Plex media server (PMS) is installed on:
Where your media is stored (e.g. internal drive):
Internal drive
The PlexConnect version number. If using Github source then a time and date of download (look at the creation date of the folder) and if you are using any testing branch e.g. the Elan/PlexInc one.
Git clone from 20/6-2012 (9pm)
The content of your 'Settings.cfg' file (if you do not have this file you are running an old version, please update)
[PlexConnect]
port_pms = 32400
enable_plexgdm = True
ip_dnsmaster = 10.0.1.1
ip_webserver = 0.0.0.0
loglevel = Normal
enable_dnsserver = True
ip_pms = 192.168.178.10
port_webserver = 80
Detail on the media file if it is an issue related to playing a media file
A detailed description of the issue (the clearer you can make this the better):
When browsing TV-shows with spesial episodes, the season with the special episode (or whole show) won't be available ("Trailers is unavailable. Try again later."). This are episodes named like e.g. S04E00 and listed in Plex/Web as UNKNOWN where others have E01 etc.
Attach 'PlexConnect.log' from your PlexConnect home directory. If possible, follow these steps to create a "fresh" one:
22:15:09 DNSServer: DNS request received!
22:15:09 DNSServer: Source: ('10.0.1.7', 53370)
22:15:09 DNSServer: Domain: trailers.apple.com
22:15:09 DNSServer: ***intercept request
22:15:09 DNSServer: -> DNS response: 10.0.1.6
22:15:09 WebServer: serving .xml: /library/metadata/2994/children
22:15:11 ATVLogger: loadAndSwapURL (override): http://trailers.apple.com/library/metadata/2987/children
22:15:11 WebServer: serving .xml: /library/metadata/2987/children
22:15:11 WebServer: serving /home/kjetil/plex/PlexConnect/assets/utils.js
22:15:11 WebServer: serving /home/kjetil/plex/PlexConnect/assets/scrobble.js
22:15:13 ATVLogger: loadURL (override): http://trailers.apple.com/library/metadata/2994/children
22:15:13 WebServer: serving .xml: /library/metadata/2994/children
gnus
Edit: correction
