Trailers is Unavailable Try Again Later
Apple TV Version: 2
Firmware: 5.3
DNS: My PC IP, 192.168.1.141
OS: Windows 7 x64, Service Pack 1
PMS Version: 0.9.7.28
Python Version: 2.7.5 Windows
Port: 52703 (80 is being used, by something else n/a)
SETTINGS.CFG
[PlexConnect]
port_pms = 32400
enable_plexgdm = True
ip_dnsmaster = 8.8.8.8
ip_webserver = 0.0.0.0
loglevel = Normal
enable_dnsserver = True
ip_pms = 192.168.1.141
port_webserver = 52703
PLEXCONNECT.LOG
17:15:16 PlexConnect: started: 17:15:16
17:15:16 PlexConnect: ***
17:15:16 PlexConnect: PlexConnect
17:15:16 PlexConnect: Press CTRL-C to shut down.
17:15:16 PlexConnect: IP_self: 192.168.1.141
17:15:17 DNSServer: started: 17:15:17
17:15:17 WebServer: started: 17:15:17
17:15:17 DNSServer: ***
17:15:17 DNSServer: Starting up.
17:15:17 DNSServer: intercept trailers.apple.com: 192.168.1.141
17:15:17 DNSServer: forward other to higher level DNS: 8.8.8.8
17:15:17 WebServer: ***
17:15:17 WebServer: WebServer: Serving HTTP on 0.0.0.0 port 52703.
17:15:17 PlexGDM: ***
17:15:17 PlexGDM: looking up Plex Media Server
17:15:18 PlexGDM: servers discovered: 1
17:15:18 XMLConverter: PlexGDM - PMS: 192.168.1.141:32400
17:16:32 DNSServer: DNS request received!
17:16:32 DNSServer: Source: (‘192.168.1.136’, 50678)
17:16:32 DNSServer: Domain: p7-buy.itunes.apple.com.akadns.net
17:16:32 DNSServer: ***forward request
17:16:32 DNSServer: -> DNS response from higher level
17:16:34 DNSServer: DNS request received!
17:16:34 DNSServer: Source: (‘192.168.1.136’, 57103)
17:16:34 DNSServer: Domain: trailers.apple.com
17:16:34 DNSServer: ***intercept request
17:16:34 DNSServer: -> DNS response: 192.168.1.141
17:16:35 DNSServer: DNS request received!
17:16:35 DNSServer: Source: (‘192.168.1.136’, 59695)
17:16:35 DNSServer: Domain: itunes-cdn.apple.com.akadns.net
17:16:35 DNSServer: ***forward request
17:16:35 DNSServer: -> DNS response from higher level
17:16:35 DNSServer: Source: (‘192.168.1.136’, 58124)
17:16:35 DNSServer: Domain: ax.init-cdn.itunes.apple.com.akadns.net
17:18:08 PlexConnect: Shutting down.
17:18:08 WebServer: Shutting down.
17:18:10 DNSServer: Shutting down.
  • port_webserver = 52703
need to be
  • port_webserver = 80
It wont let me use port 80, it says:
20:37:53 WebServer: Failed to connect to HTTP on 0.0.0.0 port 80: [Errno 10013] An attempt was made to access a socket in a way forbidden by its access permissions
I then typed into CMD this:
netstat -o -n -a | findstr 0.0:80
And this came up:
TCP    0.0.0.0:80             0.0.0.0:0              LISTENING       4
I then checked Task Manager and PID 4 is this:
So what do I do?
Need to figure out what is using port 80, you could try opening a web page using http://ipofwindowsbox and see what opens up.
Try using this:
http://technet.microsoft.com/en-gb/sysinternals/bb897437
