another - Trailers unavailable
Windows
7
Atv software
5.3
Server ip
172.16.1.101
Atv ip
172.16.1.15
Atv dns
192.168.1.101
Plex Works on other devices
have a rule set up on Windows firewall for python.exe inbound but, right now I have the firewall turned off
[PlexConnect]
ip_pms = 192.168.178.10
enable_dnsserver = True
ip_webserver = 0.0.0.0
enable_plexconnect_autodetect = True
port_pms = 32400
port_webserver = 80
ip_plexconnect = 0.0.0.0
ip_dnsmaster = 8.8.8.8
loglevel = Normal
logpath = .
enable_plexgdm = True
21:06:38 PlexConnect: started: 21:06:38
21:06:38 PlexConnect: IP_self: 192.168.1.101
21:06:38 DNSServer: started: 21:06:38
21:06:38 DNSServer: ***
21:06:38 DNSServer: Starting up.
21:06:38 DNSServer: intercept trailers.apple.com: 192.168.1.101
21:06:38 DNSServer: forward other to higher level DNS: 8.8.8.8
21:06:38 WebServer: started: 21:06:38
21:06:38 WebServer: Failed to connect to HTTP on 0.0.0.0 port 80: [Errno 10013] An attempt was made to access a socket in a way forbidden by its access permissions
21:06:51 DNSServer: DNS request received!
21:06:51 DNSServer: Source: ('192.168.1.15', 56238)
21:06:51 DNSServer: Domain: trailers.apple.com
21:06:51 DNSServer: ***intercept request
21:06:51 DNSServer: -> DNS response: 192.168.1.101
You have something hogging port 80 already.
Use netstat or similar to find out what it is and post here.
