Trailers is Unavailable
Adding to the fray :)
Here's my log
01:08:06 PlexConnect: started: 01:08:06
01:08:06 PlexConnect: Version: 0.5-dev
01:08:06 PlexConnect: Python: 2.7.6 (default, Sep  9 2014, 15:04:36)
[GCC 4.2.1 Compatible Apple LLVM 6.0 (clang-600.0.39)]
01:08:06 PlexConnect: Host OS: darwin
01:08:06 PlexConnect: PILBackgrounds: Is PIL installed? False
01:08:06 Settings: getsetting enable_plexconnect_autodetect=True
01:08:06 PlexConnect: IP_self: 10.0.1.28
01:08:06 Settings: getsetting hosttointercept=trailers.apple.com
01:08:06 ATVSettings: init class CATVSettings
01:08:06 ATVSettings: load settings
01:08:06 Settings: getsetting enable_dnsserver=True
01:08:06 DNSServer: started: 01:08:06
01:08:06 Settings: getsetting port_dnsserver=53
01:08:06 Settings: getsetting ip_dnsmaster=8.8.8.8
01:08:06 Settings: getsetting prevent_atv_update=True
01:08:06 DNSServer: ***
01:08:06 DNSServer: DNSServer: Serving DNS on 10.0.1.28 port 53.
01:08:06 DNSServer: intercept: ['trailers.apple.com'] => 10.0.1.28
01:08:06 DNSServer: restrain: ['mesu.apple.com', 'appldnld.apple.com', 'appldnld.apple.com.edgesuite.net'] => 127.0.0.1
01:08:06 DNSServer: forward other to higher level DNS: 8.8.8.8
01:08:06 WebServer: started: 01:08:06
01:08:06 Settings: getsetting port_webserver=80
01:08:06 WebServer: ***
01:08:06 WebServer: WebServer: Serving HTTP on 10.0.1.28 port 80.
01:08:06 Settings: getsetting enable_webserver_ssl=True
01:08:06 Settings: getsetting port_ssl=443
01:08:06 Settings: getsetting certfile=./assets/certificates/trailers.pem
01:08:06 WebServer: WebServer: Serving HTTPS on 10.0.1.28 port 443.
01:08:53 DNSServer: DNS request received!
01:08:53 DNSServer: Source: ('10.0.1.18', 52989)
01:08:53 DNSServer: Domain: trailers.apple.com
01:08:53 DNSServer: ***intercept request
01:08:53 DNSServer: -> DNS response: 10.0.1.28
Certs? Firewall?
trailers.cer and trailers.pem is in the assets/certificates directory. Profile is added to ATV (successfully).
Firewall is off, all ports open
I got it working.
Originally I had downloaded the zip file off GitHub and moved it into the directory. This time I used the git commands to pull the repository into my /Applications folder. Copied the certs back in, and magically everything is working now.
Fantastic piece of working code, the interface is surprisingly similar to PHT. I'm watching videos now already. Thank you very much for creating this!
