Ok, this stopped a week or so ago.
I have reset the apple TV, updated to 6.0, restarted my imac, removed and readded plex.
Banging my head here.
Plex version Version 0.9.8.6.175-88ffbb2
I started to have issues when I installed 10.8.5.But none of apple's fixes should interfere.
terminal file
Jasons-iMac:PlexConnect jason$ sudo ./PlexConnect.py
20:53:16 PlexConnect: ***
20:53:16 PlexConnect: PlexConnect
20:53:16 PlexConnect: Press CTRL-C to shut down.
20:53:16 PlexConnect: started: 20:53:16
20:53:16 PlexConnect: IP_self: 192.168.0.15
20:53:16 DNSServer: started: 20:53:16
20:53:16 DNSServer: ***
20:53:16 DNSServer: DNSServer: Serving DNS on port 53.
20:53:16 DNSServer: intercept: ['trailers.apple.com', 'atv.plexconnect'] => 192.168.0.15
20:53:16 DNSServer: restrain: ['mesu.apple.com', 'appldnld.apple.com', 'appldnld.apple.com.edgesuite.net'] => 127.0.0.1
20:53:16 DNSServer: forward other to higher level DNS: 8.8.8.8
20:53:16 WebServer: started: 20:53:16
20:53:16 WebServer: ***
20:53:16 WebServer: WebServer: Serving HTTP on 0.0.0.0 port 80.
20:53:16 WebServer: WebServer: Serving HTTPS on 0.0.0.0 port 443.
20:53:16 PlexGDM: ***
20:53:16 PlexGDM: looking up Plex Media Server
20:53:17 PlexGDM: servers discovered: 1
20:53:17 XMLConverter: PlexGDM - PMS: 192.168.0.15:32400
20:54:20 DNSServer: DNS request received!
Log file.
20:53:16 Settings: getsetting enable_plexconnect_autodetect=True
20:53:16 Settings: getsetting enable_dnsserver=True
20:53:16 Settings: getsetting port_dnsserver=53
20:53:16 Settings: getsetting ip_dnsmaster=8.8.8.8
20:53:16 Settings: getsetting prevent_atv_update=True
20:53:16 Settings: getsetting ip_webserver=0.0.0.0
20:53:16 Settings: getsetting port_webserver=80
20:53:16 Settings: getsetting enable_webserver_ssl=True
20:53:16 Settings: getsetting port_ssl=443
20:53:16 Settings: getsetting certfile=./assets/certificates/trailers.pem
20:53:16 ATVSettings: init class CATVSettings
20:53:16 ATVSettings: load settings
20:53:16 Settings: getsetting enable_plexgdm=True
20:53:16 PlexGDM: Sending discovery message: M-SEARCH * HTTP/1.0
20:53:16 PlexGDM: Received data from ('192.168.0.15', 32414)
20:53:16 PlexGDM: Data received:
HTTP/1.0 200 OK
Content-Type: plex/media-server
Resource-Identifier: b80ce4518df58bc93527049e31b3bc703d4e326d
Name: Jason Plex Server
Port: 32400
Updated-At: 1379815410
Version: 0.9.8.6.175-88ffbb2
20:53:17 PlexGDM: Jason Plex Server 192.168.0.15:32400
20:53:17 ATVSettings: setOption: update pms_uuid to ('b80ce4518df58bc93527049e31b3bc703d4e326d',)
20:54:20 DNSServer: Source: ('192.168.0.18', 56628)
20:54:20 DNSServer: Domain: 12-courier.push.apple.com
20:54:20 DNSServer: ***forward request
20:54:20 DNSServer: -> DNS response from higher level
20:54:21 DNSServer: DNS request received!
20:54:21 DNSServer: Source: ('192.168.0.18', 56628)
20:54:21 DNSServer: Domain: 12-courier.push.apple.com
20:54:21 DNSServer: ***forward request
20:54:21 DNSServer: -> DNS response from higher level
20:54:24 DNSServer: DNS request received!
20:54:24 DNSServer: Source: ('192.168.0.18', 56628)
20:54:24 DNSServer: Domain: 12-courier.push.apple.com
20:54:24 DNSServer: ***forward request
20:54:24 DNSServer: -> DNS response from higher level
20:54:33 DNSServer: DNS request received!
20:54:33 DNSServer: Source: ('192.168.0.18', 56628)
20:54:33 DNSServer: Domain: 12-courier.push.apple.com
20:54:33 DNSServer: ***forward request
20:54:33 DNSServer: -> DNS response from higher level
21:04:05 DNSServer: DNS request received!
21:04:05 DNSServer: Source: ('192.168.0.18', 49427)
21:04:05 DNSServer: Domain: 40.courier-push-apple.com.akadns.net
21:04:05 DNSServer: ***forward request
21:04:05 DNSServer: -> DNS response from higher level
21:19:15 DNSServer: DNS request received!
21:19:15 DNSServer: Source: ('192.168.0.18', 54162)
21:19:15 DNSServer: Domain: 38-courier.push.apple.com
21:19:15 DNSServer: ***forward request
21:19:17 DNSServer: -> DNS response from higher level
21:19:17 DNSServer: DNS request received!
21:19:17 DNSServer: Source: ('192.168.0.18', 54162)
21:19:17 DNSServer: Domain: 38-courier.push.apple.com
21:19:17 DNSServer: ***forward request
21:31:50 DNSServer: DNS request received!
21:31:50 DNSServer: Source: ('192.168.0.18', 60468)
21:31:50 DNSServer: Domain: 18-courier.push.apple.com
21:31:50 DNSServer: ***forward request
21:31:50 DNSServer: -> DNS response from higher level
21:42:05 DNSServer: DNS request received!
21:42:05 DNSServer: Source: ('192.168.0.18', 51073)
21:42:05 DNSServer: Domain: 21.courier-push-apple.com.akadns.net
21:42:05 DNSServer: ***forward request
21:42:06 DNSServer: -> DNS response from higher level
21:52:21 DNSServer: DNS request received!
21:52:21 DNSServer: Source: ('192.168.0.18', 56955)
21:52:21 DNSServer: Domain: 25-courier.push.apple.com
21:52:21 DNSServer: ***forward request
21:52:21 DNSServer: -> DNS response from higher level
22:02:36 DNSServer: DNS request received!
22:02:36 DNSServer: Source: ('192.168.0.18', 63322)
22:02:36 DNSServer: Domain: 31-courier.push.apple.com
22:02:36 DNSServer: ***forward request
22:02:36 DNSServer: -> DNS response from higher level
22:12:51 DNSServer: DNS request received!
22:12:51 DNSServer: Source: ('192.168.0.18', 51041)
22:12:51 DNSServer: Domain: 23.courier-push-apple.com.akadns.net
22:12:51 DNSServer: ***forward request
22:12:51 DNSServer: -> DNS response from higher level
22:23:05 DNSServer: DNS request received!
22:23:05 DNSServer: Source: ('192.168.0.18', 60569)
22:23:05 DNSServer: Domain: 16-courier.push.apple.com
22:23:05 DNSServer: ***forward request
22:23:05 DNSServer: -> DNS response from higher level
22:33:20 DNSServer: DNS request received!
22:33:20 DNSServer: Source: ('192.168.0.18', 62289)
22:33:20 DNSServer: Domain: 28.courier-push-apple.com.akadns.net
22:33:20 DNSServer: ***forward request
22:33:20 DNSServer: -> DNS response from higher level
22:43:35 DNSServer: DNS request received!
22:43:35 DNSServer: Source: ('192.168.0.18', 55943)
22:43:35 DNSServer: Domain: 33-courier.push.apple.com
22:43:35 DNSServer: ***forward request
22:43:35 DNSServer: -> DNS response from higher level
22:53:50 DNSServer: DNS request received!
22:53:50 DNSServer: Source: ('192.168.0.18', 52197)
22:53:50 DNSServer: Domain: 14.courier-push-apple.com.akadns.net
22:53:50 DNSServer: ***forward request
22:53:50 DNSServer: -> DNS response from higher level
23:04:05 DNSServer: DNS request received!
23:04:05 DNSServer: Source: ('192.168.0.18', 51487)
23:04:05 DNSServer: Domain: 29-courier.push.apple.com
23:04:05 DNSServer: ***forward request
23:04:05 DNSServer: -> DNS response from higher level
23:14:20 DNSServer: DNS request received!
23:14:20 DNSServer: Source: ('192.168.0.18', 62261)
23:14:20 DNSServer: Domain: 42.courier-push-apple.com.akadns.net
23:14:20 DNSServer: ***forward request
23:14:20 DNSServer: -> DNS response from higher level
23:24:35 DNSServer: DNS request received!
23:24:35 DNSServer: Source: ('192.168.0.18', 61865)
What am I missing here?
