Trancoding error for all DVR shows since 11/12/2017
Every program that I record fails after a few seconds to a few minutes with a: “There was a transcoder error” This is true is it is a scheduled recording or if I start recording something immediately. I have upgraded and rebooted server 2x with no change. Attached are the logs
I should have mentioned that I have 2 SiliconDust HDHomeRun Prime TV Tuner as the source with up to date firmware
Model: HDHR3-CC
Device ID: 132584D2
Firmware: 20170930
So do you have 2 Prime tuners? The Plex Tuner Service log file appears to be only seeing one tuner device:
Nov 21, 2017 08:56:42.161 [7852] INFO - * DeviceGetListEx_impl: Filter [Silicondust HDHomeRun Tuner 1054E529-0]
I see the following errors in your Plex Media Server log file for the 9:00 recording time:
Nov 21, 2017 09:00:06.688 [9548] ERROR - DVR:Device: Error refreshing existing device device://tv.plex.grabbers.hdhomerun/1054E529, marking as dead.
Nov 21, 2017 09:51:07.516 [3020] ERROR - [Transcoder] http://10.0.1.42:5004/auto/v1651: Server returned 404 Not Found
Is your device working? From the last entry above it seems like the device was seen again at 9:51 but the device returned an error (404 Not Found) when Plex tried to tune to channel 1651.
You might want to redo the DVR setup for the device and verify channel mappings.
thanks johnm_ColaSC will take your advice
