Transcode container
Server Version#:latest
Player Version#:webOS
Hi everyone.
Since a few weeks, my Plex server is transcoding (only container mkv to mpeg) aproximately at the middle of a movie.
At first it direct play well. In x264 or x265 same issue.
How can I stay in direct play ?
Thanks for your help.
Is it similar to this?
Yes it looks like.
Now it transcode every mkv !
It really weird. Is it a way to fix this ?!
Can you please fix the LG pmp ?!
It’s impossible to direct play x265 mkv files know !!
I’ve a lot of HD light x265 files with low bitrates (between 2/4 Mbps) but with this forcing transcoding in mpegts the bandwidth is 3x much bigger … so with my low connection its buffering every 2min !
That’s very annoying :triumph:
And the best part: if I want to downgrade the quality I’ve only the choice with ugly sd 720kbps or 320kbps !!!
Can someone help me with those direct play issues ?!
Even if I disable subs it still transcode mkv files !
Thanks.
