Transcoder crash with audio tracks "TRUEHD 7.1"
Server Version#: 1.41.3.9314 (running on truenas using the plex pass image)
Player Version#: updated Plex for LG 5.90.1 (client) 9.2.1 (platform)
Every times I play a movie for which the audio track is “TRUEHD 7.1” the transcoder crashes.
The TV does not support DTS audio (if I enable in the client setting I do not hear anything) and because of that the transcoder for audio (video is direct play) starts. I got a transcoding to “EAC3” but is seems that also disabling this format in the client does not fix the issue.
That seems a bug in the transcoder.
Here the errors I get and a truncated log file from when the issue happens:
Dec 22, 2024 11:24:56.904 [139794707462968] ERROR - [Req#2901a/Transcode/s79qt0m5irsp2omrc58z9b3z/9d706ede-fa84-4344-bdc8-2d8b92761634] [matroska,webm @ 0x7f1a66c48bc0] 0x00 at pos 1092092472 (0x41180238) invalid as first byte of an EBML number
Dec 22, 2024 11:24:56.932 [139794698177336] ERROR - [Req#2901b/Transcode/s79qt0m5irsp2omrc58z9b3z/9d706ede-fa84-4344-bdc8-2d8b92761634] [stream_segment,ssegment @ 0x7f1a645ec680] Error applying bitstream filters to an output packet for stream #0: Invalid data found when processing input
Dec 22, 2024 11:24:56.932 [139794729925432] ERROR - [Req#2901e/Transcode/s79qt0m5irsp2omrc58z9b3z/9d706ede-fa84-4344-bdc8-2d8b92761634] av_interleaved_write_frame(): Invalid data found when processing input
That happens with almost all movies that have “TRUEHD 7.1” track.
Could you provide some feedback and possibly a fix ?
Thanks!
Plex Media Server.log (9.2 KB)
This bug seems quite severe… how is possible nobody looks into it ?
